bbc replacement oil pan question
Old Aug 17, 2006 | 08:09 AM
mfgaffney's Avatar
mfgaffney
Default bbc replacement oil pan question
My current stock pan is dinged up on my 74, and I am going to replace it. Anybody offer some advice about what works/fits other than stock?
Old Aug 17, 2006 | 08:21 AM
S489's Avatar
S489
i had a tough time finding one that didn't have a deep sump so i just had one made; it's no lower than a fact SBC pan:
some on the forum use moroso i think.
Old Aug 17, 2006 | 10:08 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Moroso Performance makes several pans for your application. Call their tech department.
Old Aug 17, 2006 | 02:46 PM
Hvymtlc5's Avatar
Hvymtlc5
Many clones on ebay...the one I bought from Fatrodder ebay sales is a 7 qt and fit well, but have heard that some don't line up (bolt holes) well.
Old Aug 18, 2006 | 12:14 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
What engine? GM is still making pans,..that's where I'd go. I'll never buy another Moroso,..bought one for a 496 on a 69 Camaro and the radius was bad at the rear seal causing me to pull the engine twice. Went to a Milodon,..no problems.
But by going GM you know your oil pump pick-up would be spot on.
Good luck!
Old Aug 18, 2006 | 12:54 AM
PolishMike's Avatar
PolishMike
i like my moroso on my 502.
Old Aug 18, 2006 | 08:58 AM
S489's Avatar
S489
when researching for your pan, also consider some vette owners have had issues with oil pick-up, or lack thereof, during hard braking, cornering, etc. So the pan baffling needs to keep oil at the pickup during these manouvers. most gm pans have little or no baffling around the pick-up (but haven't seen the brand new ones; maybe someone could post inside pics). not sure if there is anything on this forum re: this subject, but it's been documented in other readily available references, however, the articles are old and havn't been updated to my knowledge. one article i found refers to modifiying an aftermarket pan to fix the pick-up issue. i contacted the same aftermarket manufacturer (well known brand) about this and got nowhere with sales; and couldn't get through to engineering; was hoping they had incorporated mods. for daily driver type action, a gm pan, windage tray, and pick up should work great. many run the 8" deep gm pan with no issue. but if you need less depth (more ground clearance), my experience last year was no luck finding an off the shelf item with good proven baffling from any aftermarket brand.
Old Aug 18, 2006 | 09:15 AM
sxr6's Avatar
sxr6
Would that be the 1 ton truck GM pan your refering to??
I have asked many if that pan would fit a BB vette to no avail!
Old Aug 18, 2006 | 09:31 AM
S489's Avatar
S489
i had one off of a 95 truck that didn't work for me; the 8" was just too deep. i didn't go any further, but am thinking the truck pan also won't clear the factory PS. i think gm has another bb 8" pan; don't have all the info with me right now . . . gm performance gave me a part number, it's in their catalog; just guessing that it's different from the truck pan somehow with a different part number.
Old Aug 18, 2006 | 09:59 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
If you want genuine GM, just get the old LS-7 pan/pickup and windage tray. It's a great pan and should fit OK. Never any pressure issues with it that I've ever heard of.
Well actually, I'm not sure if it clears PS if you have it. Might need to check that with someone else.
Otherwise there are a couple of other hardcore pans out there, but I'm not sure that's what you're looking for.
JIM
Old Aug 20, 2006 | 10:23 PM
sxr6's Avatar
sxr6
I did a rough measurment & found the pan from a 86 BB truck to be only 1/2" deaper than the pan that's currently on the 350 in the car!
Course I'm trying to measure with vette sitting on the ground
makes reaching under a little difficult
Old Aug 21, 2006 | 08:53 AM
S489's Avatar
S489
Yea, the main thing is you have a heads up on the issue. If you measure first you won't be surprised or disappointed later.
Try measuring from the pan rail down and from the lowest point on the rear main down. Grab a straight edge for the bottom of the pan and take several measurements. Also use the tranny and tranny dust cover as general reference points for eye-balling, maybe that will help. I think you'll end up having to jack up the car. Trying to measure for PS clearance is tricky without fixtures; i missed it by about 3/8" on my first try using tape, squares, and fiddle-t-widgets. The assist cylinder is closest to the pan when wheels are locked left.
The 1/2" lower on the 86 pan would be great if all else works; i'd assume that the windage and pick-ups are different.
427Hotrod has good suggestion too; you may find the old LS-7 pan/pickup and windage tray to work well. If all you have is dings on the factory pan, seems like the easiest solution is a replacement in kind.
If you mix/match parts, just make sure to check the standard items like oil pickup to pan clearance, etc., and that the windage scheme is consistent. If you are already getting dings on the pan, don't consider AL, stay with sheet metal.
To bbc replacement oil pan question
