I been doing a little reading. :D . So how do I increase my low end torque by going from a 67cc which is stock to a 64cc?? Anyone know how this kind of stuff works?
Re: How does a 64cc chamber increase low torque? (xfactor974)
Raising the compression is one way to increase cylinder pressure. Cylinder pressure increases build torque. To much cylinder pressure can cause predetonation. So there is a fine line between optimum cylinder pressure and too much pressure. The cam timing is the other major factor that determines cylinder pressure.
All of the things posted are correct for sure. One more thing though, a small head chamber also promotes better frame travel across the piston dome. This also helps with a tune-up, as the charge is not as violent. The best set-up for optimum power regardless of compression ratio is to have the smallest dome possible with the chamber sized for the correct compression ratio wanted. On my 385 I had a 60 cc chamber and 3 cc dome to get a healthy 12.75 to 1.
Re: How does a 64cc chamber increase low torque? (Nomad78SA)
Neil,
The motor was not a deal were I drove it much on the street. It was in my Pro Street Camaro that is on my web site, check it out. But to answer your question, I ran 110 octane for cruising and VP C-16 or 116 octane when I raced or used the NOS. I did use pump gas in it once when I got caught short on a cruise night. But I did not get over 3000 rpm so I was not building any cylinder pressure. The higher the octane rating the less prone to pre-ignition.
