T-Top adjustment
Old Aug 18, 2006 | 12:07 PM
merlin5353's Avatar
merlin5353
St. Jude Donor '07-'08-'09-'10
Default T-Top adjustment
My '71 has a t-top gap you could drive a semi through! It's gotta be an inch. It was like this when I bought the car several years ago. Since I've fixed the other items on my (long) list, I'm getting down to this one. Can the top pin be adjusted?
Old Aug 19, 2006 | 04:14 AM
grybdn's Avatar
grybdn
pic's
Old Aug 19, 2006 | 05:46 AM
Bob Onit's Avatar
Bob Onit
Originally Posted by grybdn
pic's
Having a hard time understanding your explaination???
Old Aug 19, 2006 | 07:58 AM
kb2fzq's Avatar
kb2fzq
An inch?
Try and send some pictures...doesn't seem possible...
Old Aug 19, 2006 | 09:59 AM
GaryS's Avatar
GaryS
The vinyl liner on your T-top can be removed relatively easily. Once the liner is off, you will see that the pins are held on with two bolts and can be loosened and then the top reinstalled. Once the top is on you can see where the adjustment needs to be made.
IIRC, the GM Service Manual gives an adjustment procedure for this. Do you have one?
Gary
Old Aug 19, 2006 | 03:19 PM
merlin5353's Avatar
merlin5353
Yep, I've got the AIM and service manuals. Seems like the tops have been 'outboard' for a long time; the A-pillar trim is pretty chewed up at the top by the top hold-down clamps. I'll take the inside vinyl pad off and check it out.
BTW, I'll get some pics posted.........
Old Aug 20, 2006 | 04:39 PM
merlin5353's Avatar
merlin5353
Here's a couple of pics. It's about 3/4 inch. Also, what type of socket is used to loosen up the front pin? It looks like an inverse 'torx'.
Old Aug 20, 2006 | 06:52 PM
IDOXLR8's Avatar
IDOXLR8
I would start by removing the out sid guide pin and the trianglar outside bolt and loosen the two center support see what part is out of adjusment. The gaps are a little wide but not as wide as yours. I attached a picture of mine, AL.
To T-Top adjustment
