Speedo/tach cluster dash re-install-HELP!!
Old Aug 19, 2006 | 12:29 PM
A72COUPEDT's Avatar
A72COUPEDT
Default Speedo/tach cluster dash re-install-HELP!!
Just comming up short with the speedo/tach cables...
I have removed ALL the trim and dropped the steering wheel.
Since it's been a while..I have forgotten positions of the wiring harness bundle and headlight plugs etc....
I'm about a 1/2" short of the speedo/tach cable hookup and DON"T wanna push or crack/damage anything.
I deserve a swift kick in the a** for NOT taking pics...I know.
ANY AND ALL HELP TIPS PLEASE....
Old Aug 19, 2006 | 09:12 PM
Sayfoo's Avatar
Sayfoo
I had my 69 apart recently, and had the same situation. I messed around with it for a while, then "bit the bullet" and just pressed it back in place. As you know, it't hard to see anything and wires and cables hang down, so what are you going to do? Good luck.
Old Aug 20, 2006 | 12:15 AM
StickShiftCorvette's Avatar
StickShiftCorvette
The main bundle of the wiring harness must be high and to the left. I zip tied mine to keep it in position. Remember, the trip meter cable CANNOT be preassembled in the padding as one would think. You can have it on the speedo, but MUST thread it behind the cross bracing and then install the bottom after the entire assembly is in place.
To Speedo/tach cluster dash re-install-HELP!!
