Freon Capacity
Old Aug 19, 2006 | 03:10 PM
bmankin's Avatar
bmankin
Default Freon Capacity
I can not find the original freon capacity on a 1977 with a R4 compressor. Can anyone help?
Old Aug 19, 2006 | 05:39 PM
Durango_Boy's Avatar
Durango_Boy
Call a shop or a dealership service center. Shops that can do an AC flush and fill have to be able to look it up. They will probably be able to look it up for you.
Old Aug 19, 2006 | 06:17 PM
chevylit's Avatar
chevylit
In the specs section of My 77 Owners manual it shows 11oz of compressor oil and 3 lbs of R12. Ah yes,the good old days when R12
was available everywhere for 99 cents a lb.
Old Aug 19, 2006 | 06:19 PM
Durango_Boy
It's what now? $12 a lb for 134?
Old Aug 19, 2006 | 11:58 PM
bmankin's Avatar
bmankin
Thanks, That translates into about 40 oz of 134A right?
Old Aug 20, 2006 | 01:33 AM
Bob Onit's Avatar
Bob Onit
I believe R134a only requires 85% of the original R12 capacity.
Im sure somone will correct me if I'm wrong
Old Aug 20, 2006 | 01:42 AM
IDOXLR8's Avatar
IDOXLR8
R-12 is still around and I would not change it over unless you have leak issues. The system in you car is set up to work with R-12 and converting it over causes contamination issues and heat tranfer issues because R-134 needs a larger condensor and more refrigerant to work properly and yours is made for R-12, AL.
Old Aug 20, 2006 | 08:14 AM
bmankin's Avatar
bmankin
I had to get a new compressor,hoses and drier so I went ahead and converted to 134A. I've got an electric fan installed also so I'm hoping that will help.
Old Aug 20, 2006 | 08:33 AM
IDOXLR8's Avatar
IDOXLR8
I've seen many change overs go well but its R-12 for me. When you changed your system over did you go to a different Orifice/screen or use the same one that would have been used with R-12? AL.
Old Aug 20, 2006 | 09:47 AM
Durango_Boy
The other thing to consider when changing to 134 is this. A 134 system cannot have flaws ot it loses up to 40% efficiency. You have to completely flush and clean the system, probably a shop would be best suited for this.
You have to replace the drier with a new, larger unit...not hard.
And you have to make sure the radiator and condensor have no bent fins and no blockages.
With a good designed 134 system, good airflow, with no trash is the system, you can have 40 degree air. I've seen in done in a converted '57 Chevy. Froze my ***** off.
Old Aug 20, 2006 | 12:11 PM
IDOXLR8's Avatar
IDOXLR8
The other thing is the higher head presures. I've seen many change over systems work very well, but as long as R-12 is around I'm not changing mine over. I see duct temps well below 40 degrees and some times it get uncomfortabily cold and can see my breath, AL.
Old Aug 20, 2006 | 12:14 PM
Durango_Boy
I used to have a Taurus, when I was 18. It's AC system was amazing. It would blow chunks of frost at me along with sub 40 degree temps.
Old Aug 20, 2006 | 02:46 PM
bmankin's Avatar
bmankin
I did change the orifice/screen. I'm close to the end of a complete restoration so I had every AC component out of the vehicle. It was setting with a zero R12 charge so it just seemed like the thing to do. I have access to gauges vacuum pump, recovery machine and any thing else that might be used. I'm a little nervous about the outcome, but worse case scenario I can take it back to R12 without to big of an ordeal. That is if the oil I used is backwards compatible with R12
Old Aug 20, 2006 | 02:53 PM
Durango_Boy
I don't believe it is, but hopefully someone else has that answer too.
Old Aug 20, 2006 | 06:10 PM
IDOXLR8's Avatar
IDOXLR8
The oils are not compatable and if one is used and changed over the system must be flushed completely. That is why its inportant to have an idea on what way you want to go from the start. If your going from square one with all new parts then a change over has a good chanch of working okay but on the other hand it is tuff to remove all the old refridgarant oil and have it completly cleaned out. I had a r-12 system in my car and did not change it over because there has never been any signs of leaks and the R-12 was designed for that car. To really have the system work to 100 percent would require a larger condensor, higher pressure hoses, correct compressor, correct dryer, correct orfic/screen, because of the higher head pressures and non minerial oil used in the R-134a not to mention that the goverment has announced that the R-134a has globle warming potential and is slated to be dropped like R-12. This may be the reason the price has been on the rise, so in short I would stay with the R-12 if possable, AL.
Old Aug 20, 2006 | 06:13 PM
Durango_Boy
Yikes...do they have a cleaner refrigerent to use when that happens?
Old Aug 20, 2006 | 06:55 PM
IDOXLR8's Avatar
IDOXLR8
The R-12 deal all over again with R-134a , AL.
To Freon Capacity
Old Aug 20, 2006 | 07:38 PM
Durango_Boy
They'll figure it out...they always do. Maybe expensive to change, but with todays chemical technology being what it is it should be very efficient.
Old Aug 20, 2006 | 08:05 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I think there is a mineral oil that is compatible with 12 and 134a. Who knows what they're gonna come up with next, but I need to take my A/C apart, so I'm going to go ahead and switch to 134a (but I'm going to get my 609 certification just in case). Dang scientists...just invent a non-polluting, non-flammable refrigerant once and for all and get it over with.
Old Aug 20, 2006 | 08:06 PM
Durango_Boy
Ahmen brother...*High Five.*
