Holley or Demon 650?
Old Aug 19, 2006 | 08:07 PM
Sprzout's Avatar
Sprzout
Default Holley or Demon 650?
We're in the process of rebuilding our engine, and are trying to buy some parts for our SB.
Well, one of the things that we're going to end up buying is an Edelbrock top end package, with the E-Tec heads, and the Performer Air Gap manifold. Well, the problem with this manifold is that it doesn't come in a spreadbore setup, so we can't use the old Q-Jet that's currently on the car.
Well, my dad's considering buying a Holley 650 cfm carb to drop onto the manifold, but I keep seeing the Demon Speed Demon carbs, with a 650 cfm mechanical secondary...Lots of people on the forum here seem to prefer the Demons, which is why I'm leaning towards one of those...
Ultimately, we're looking at about 425 hp after we get done with the rebuild, and will be going to a 383 stroker rebuild...
Anyone have any suggestions/ideas for which one we should go with? Pros/cons, ease of adjustment, etc?
Old Aug 19, 2006 | 08:21 PM
olescarb's Avatar
olescarb
a air gap style manifold in my opinion have a carburetor that is richer than most other manifold require because there is little or no heat in the intake manifold to keep the air & fuel mixed together at lower engine speeds. the carb i would suggest is a mighty demon or the holley 4150 HP is close second but it costs more money. a speed demon does not have changable idle jets or air bleeds so if you need to tune the air/fuel mixture it is not as easy as a mighty demon.
you may gain a little power with a air gap manifold but at the cost of normal drivabilty but the choice is yours!
henry @ oles carb
Old Aug 20, 2006 | 01:11 AM
Sprzout's Avatar
Sprzout
henry @ oles carb
Hmm...That's a thought, going with the Mighty Demon...It just seems like a whole lot of carb, though.
We're going to keep the Air Gap, though, due to the fact that it comes in the Edelbrock kit that Summit's got in their new catalog...
Old Aug 20, 2006 | 10:18 AM
Daryl Lawman's Avatar
Daryl Lawman
I still like the Holley.....I have the Holley and its been great.
Old Aug 20, 2006 | 10:52 AM
SpyderD's Avatar
SpyderD
You can always get one of those adaptor plates that adapt a spread- to squarebore. With the air gap you may have hood clearance issues however.
Read carefully some posts about the BG demon carbs, there have been quality control issues.
Finally - 425hp would be pushing it on a 650 carb, I doubt you will hit your mark. If you want that 425 HP you would probably need a 750.
Old Aug 20, 2006 | 01:32 PM
Sprzout's Avatar
Sprzout
I'm kinda afraid I'm hitting the limit of a 650, too...I haven't heard anything bad about BG carbs until now, but I'm going to take a look...Holleys I know have been around for what seems like millenia now. Maybe I'll look at a double pumper Holley, or try to get some more info on the Edelbrock Thunder Series.
I would LOVE to keep the Q-Jet, but clearances with a spread-to-square riser & the Air Gap won't allow it. As it is, I'm going to have to run a drop base air cleaner...Either that, or change to a riser hood, which I'm not wild about doing. I'm trying to keep the car with a stock appearance so that it doesn't attract too much of the wrong gaze (i.e. the 5-0)...Sounds like maybe I've got a lot more research on my hands, trying to weed out what works from the marketing . Thanks guys!
Old Aug 20, 2006 | 03:46 PM
olescarb's Avatar
olescarb
the edelbrock thunder (and performer) carbs are very good for a mild engine but they are not the best choice for a air-gap manifold and we never use a edelbrock larger than a 650cfm because of a lean of idle problem that is very common on the 750 and 800 cfm units. a hot cammed engine or a engine with a air gap manifold will respond well to a carburetor with 4 corner idle (4150HP or mighty demon)
if you choose a mighty demon i would use a 650 cfm unit (demon under rates the cfm flow while other brands overstate the cfm flow) if you go a holley 4150HP a 750 cfm should be ok. i have had as same amount of quality control problems with edelbrock, holley and barry grant, so to me it is personal preference on which carb to use.
henry @ oles carb
Old Aug 20, 2006 | 05:58 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
holleys are absolute garbage
/ thread
Old Aug 20, 2006 | 06:57 PM
66427-450's Avatar
66427-450
if it were me, i'd go with a Holley DP for a moderate street/track setup. an HP for a more serious perf setup.
cfm? 750 min... depend on RPM range and primary use.
me? i tried a Demon, went back to a Holley....... i'm sure you can make either work with enough tuning.
Old Aug 20, 2006 | 07:47 PM
75blackray's Avatar
75blackray
i have had alot of problems with my speed demon. Mainly float settings, and flooding. It shot fuel out of the top right out of the box. After taking it apart 3 times (twice b/c spare parts were left inside the carb ) and having a carb. specialist take it apart and finally get the floats to stay set. It runs great now, but I was cussing barry grant for a while. I may still eventually switch to a double pumper, but for now the demon does fine.
Old Aug 20, 2006 | 07:54 PM
Bob Onit's Avatar
Bob Onit
Does anybody remember if the air-gap fits under the 74' hood?
Old Aug 20, 2006 | 09:02 PM
Sprzout's Avatar
Sprzout
It will, but only with a drop-base air cleaner...I'm already planning to do so.
Old Aug 20, 2006 | 09:11 PM
waterplay's Avatar
waterplay
Quick Fuel with annular discharge it will atomize the fuel better in those longer runners. Idle quality is better and low-end torque is substantially higher. I have tried most carbs out there and this is by far the best route! Bar none! It is also fully tunable. That is my .02
Old Aug 21, 2006 | 12:00 AM
Little Mouse's Avatar
Little Mouse
Use a 750 cfm carb for that size engine and HP the 770 street
avenger holley or a vacuum secondary demon, if you are going
to race it a double pumper 750.
Old Aug 21, 2006 | 12:48 AM
Sprzout's Avatar
Sprzout
*IF* I race it, it'll be on the 1/8th mi. drags here once in a blue moon...But I probably won't. My dad keeps pushing for mechanical secondary, but I've been reading some stuff by Vizard that basically says we don't need a mechanical unless it's going to be full street/strip.
Cost wise, it looks like it'd be cheaper to go with the Holley, but previous posters have stated that the Demon carbs are underrated for the CFMs, whereas Holleys are overrated for CFM. So, maybe the Demons might be better? Or should I look at the Edelbrock Thunder Series, with that AVS?
Old Aug 21, 2006 | 01:56 AM
Little Mouse
I like vacuum secondary carbs they are very forgiving on a street car.
Holley/Demon they both look like a copy of one another to me LOL.
Never had an edelbrock or Demon.
Old Aug 21, 2006 | 08:14 AM
66427-450's Avatar
66427-450
*IF* I race it, it'll be on the 1/8th mi. drags here once in a blue moon...But I probably won't.......... basically says we don't need a mechanical unless it's going to be full street/strip......Cost wise, it looks like it'd be cheaper to go with the Holley......
in that case just pick up a Holley 780 Vac Sec..... very inexpensive, easy to tune to you setup (Sec spring and jets)
To Holley or Demon 650?
Old Aug 23, 2006 | 11:43 AM
Doug S's Avatar
Doug S
On a combination like this you’ll be on the borderline between a 650 and 750. A 750 with Annular boosters will give you better top end performance, however a 650 will have a little better air velocity which should give you a little crisper throttle response, and acceleration. It really boils down to what you want out of the car, more throttle response low speed driving go smaller, more top end go bigger.
As far as vacuum secondary vs. mechanical secondary; usually you’ll find a vacuum secondary carburetor on cars with automatic transmissions with less than a 2800-RPM stall speed. You’ll find mechanical secondary carburetors on vehicles with manual transmission or automatics with 2800 RPM or higher Stall Speeds. The mechanical secondary will give better throttle control in these applications.
Technical Support,
Barry Grant, Inc.
Old Aug 23, 2006 | 12:07 PM
VETMANIAC's Avatar
VETMANIAC
I have run both the BG Speed Demon 850 and a Holley 850 and Holley HP1000 on my Big Blocks. The HP1000 worked the best for me. The tune was very close out of the box for my application, and I like the fact that I could change air bleeds.
The Demons are certainly more aesthetically pleasing than the Holleys, but there have been issues. I did not experience this with my Demon, but some people have reported leftover machining shavings in their brand new Demons. If you go the Demon route, it wouldn't hurt to pull apart and make sure that there are no nasty suprises waiting to enter you motor.
Having said all of that, I know of many people that love Demons and hate Holleys and also love Holleys and curse Demons wishing hateful things on Barry Grant. I think it all comes down double checking everything before you bolt it on and knowing how to properly tune a carb.
Old Aug 23, 2006 | 12:13 PM
Sprzout's Avatar
Sprzout
Technical Support,
Barry Grant, Inc.
Doug, thanks a bunch. This is really some good information that I was looking to glean from the forums, trying to understand a little bit more as to WHY I should choose a specific type of carb. Many of the books I've been trying to read have confused me thoroughly for basics, and so I've been trying to understand it. This puts it into layman's terms for me and definitely narrows it down for me. Since we're going to be driving this on the street primarily, taking it to cruise nights, maybe a test n' tune at the 1/8th mi. drags here in SD once in a while, I think I'm going to go for a 650 CFM carb...That'll give me more of the bottom end that I'm looking for.
