Installing Side A/C Vents ?
Does someone have some good advice on installing these?
Rotating the adjustable vent 180 degrees will allow removal from the mounting frame if you want to clean it before installation in the dash. If you then reassemble the parts and position the assembly behind the dash the tab for the "inside" hex head screw is fairly easy to get positioned and the hexhead started first to hold everything in place. The outer fastener can then be installed. Use an awl to locate the hole in the dash and line up the outer mounting tab holes. Tighten the inner fastener to hold the position. I used a socket and two short extensions with the fastener held in the socket with duct tape. On the driver side this tool will be just about level and needs to be fed in from the forward side of the hood release bracket. There's no getting around the fact that it is tedious and done a lot by feel and knowing that when you do hit the mounting tab hole the screw will thread in. Taking the lower seat cushion out gives more room for your body. Good luck-this is backache territory.
