Keep braking motor mount bolts!
Old Aug 20, 2006 | 09:05 PM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by waterplay
If we pull our resources maybe we could get the rotors.
I like the idea but lets deal with your motor mount bolts first huh?
Old Aug 20, 2006 | 09:11 PM
shafrs3's Avatar
shafrs3
Perhaps your source for bolts is selling you cheap Chinese pieces?
Old Aug 20, 2006 | 09:13 PM
Rockn-Roll's Avatar
Rockn-Roll
Are we talking about the bolt that runs through the frame sleeve and the motor mount ears? If so, then your bolt may have its threads located on one of the ears which is allowing it to have some impact force as well as shear and placing most of the shear on the ear which isn't loose on the bolt threads...this is the only thing that can explain it from my viewpoint. Make sure that the bolt shaft is solid all through the frame sleeve and on both of the motor mount ears...the nut doesn't have to be tight to hold them together...it's just there to keep the bolt on...use two nuts to lock them together if the best bolt has the solid shaft extending too far beyond the ears and requires several washers.
waterplay's Avatar
waterplay
Ok good idea. I may not ride the short bus and ware a helmet in the mall but I think I may have A.D.D.
Old Aug 20, 2006 | 09:17 PM
Durango_Boy
Me too. My mall is full of jail bait. The whole thing is full of 17 yr old girls who dress like they're 22 yr old strippers. Never seen so many short denim skirts...yikes.
What were we talking about?
Old Aug 20, 2006 | 09:18 PM
waterplay's Avatar
waterplay
Yes you may have something here! I get my bolts at the hardware store and I know the one that just failed had threads most of the way down. I wish I could have recovered the one that just broke to see where it broke. On the threads or somewhere else.
Old Aug 20, 2006 | 09:21 PM
waterplay's Avatar
waterplay
"What were we talking about?"
Sounds like we are talking about Jail time. They didnt grow that way when I was 17. Or maby they did and my issue is not A.D.D. its Old timers.
Old Aug 20, 2006 | 09:37 PM
Durango_Boy
Nor me...they didn't start that till I got to college. Now I'm 28, and I feel icky when I check out a girl, and then find out she's frig'n 17.
Anyway, back to the bolts. I think Rockn had a great point. The stock bolt was a smooth shaft all the way through, and the threading didn't start until after the last ear. Then a spacer was used to space the nut out to the threads. The contact of the ears and the frame tabs should only be to a smooth shaft of a bolt. Threaded sections of that bolt will shear and break a lot easier. I didn't even think that you were buying bolts that had threading contacting the edges of the tabs and ears.
