How can I boost vacuum?
Old Aug 20, 2006 | 08:46 PM
Durango_Boy's Avatar
Durango_Boy
Default How can I boost vacuum?
My 350 is fairly stock. I rebuilt it liek six years ago, but used stock replacement parts. The vacuum system all works...healights, climate control and the like, but sometimes it seems I have to wait for vacuum to build up before I can get the lights up quick.
I know when I build and put in the new 400 I'll have less vacuum than I do now. What are some ways I can boost vacuum in the system? Aren't there little electric vacuum pumps that pull air out aiding the vacuum system? Any thoughts?
Old Aug 20, 2006 | 09:36 PM
Bob Onit's Avatar
Bob Onit
First of all, what IS your Manifold vacuum.... get back with the number and then you may get some correct answers
Old Aug 20, 2006 | 09:38 PM
Durango_Boy
You know what? I haven't measured. I'll do that. Umm...what should it be?
Old Aug 20, 2006 | 09:40 PM
bahamasair's Avatar
bahamasair
You could always go electric. Im going this route with mine when I finally get that far in my rebuild. http://www.mcspeed.homestead.com/Our_Products.html
Old Aug 20, 2006 | 09:44 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
Anything above 10 inches of Vacuum is enough to operate the headlights and brakes.
If it's slow then you might have a bad or missing checkvalve.
There should be two ( at least ) One that plugs into the brake booster disguised as a 90 degree fitting and the other between the Vacuum can and the intake manifold.
Old Aug 20, 2006 | 09:50 PM
Durango_Boy
I'll test this, but I don't have a vacuum gauge and will need to borrow or buy one.
How long should it take an engine to achieve 10" of vacuum?
If it's slow then you might have a bad or missing checkvalve. There should be two ( at least ) One that plugs into the brake booster disguised as a 90 degree fitting and the other between the Vacuum can and the intake manifold.
Hmm...my Vette doesn't have one of these. I guess good ol' Bubby removed mine back in the '80's before I owned it. Bummer.
Could an engine achieve proper vacuum without one of these?
Old Aug 20, 2006 | 09:54 PM
Bob Onit's Avatar
Bob Onit
about as long as it takes to hook a hose to your intake mainfold
The vacuum is highest at idle
My stock L-48 reads about 20"
Old Aug 20, 2006 | 09:57 PM
...Roger...'s Avatar
...Roger...
You should have around 15" at idle-you probably just have some leaks or are missing your check valves.
Old Aug 20, 2006 | 09:59 PM
Durango_Boy
I'm sure I don't have leaks, but I"ll have to check on the check valves. Also, what about the vac can? Needed or not?
Old Aug 20, 2006 | 10:02 PM
...Roger...
Can? vacumn adv. on distributor?
Old Aug 20, 2006 | 10:06 PM
Durango_Boy
Someone mentioned the check valve between the vacuum can and the engine. My Vette does not have a vac can, and I wonder if that's why I don't have strong vacuum...or at least I assume I don't without checking with a gauge.
The reason I think it just takes time for my vac to build, or that it isn't very strong...is say I start the Vette at night, and immediately turn on the headlights. They won't pop up immediately, and they come up unevenly. If I let it idle for a few seconds, maybe 15 seconds or so, and then turn on the lights, they both pop up strong and fast.
...Roger...
Bob-- wont be 20 after that big ole cam install !!!!!
Old Aug 20, 2006 | 10:08 PM
Durango_Boy
That's the other reason I ask. I'm building a new motor, and it'll have a larger cam, a ZZ4 cam. I was told it'll have lower vacuum at idle so I started thinking I would need to boost this using an electric pump of some kind.
Old Aug 20, 2006 | 10:11 PM
...Roger...
15 seconds isnt real bad but it could be the check valve-its a 3port valve behind carb on drivers side --your vac canister is part of your front bumper_sorta-its up front a big cylinder with ports on it
Old Aug 20, 2006 | 10:12 PM
Durango_Boy
I have that one...I thought he meant the coffee can looking thing that's sometimes under the fender of the driver's side.
Old Aug 20, 2006 | 10:13 PM
...Roger...
No you shouldnt need that just tighten your system up a little!!
Old Aug 20, 2006 | 10:14 PM
...Roger...
That was earlier years-cant remember exactly.
To How can I boost vacuum?
Old Aug 20, 2006 | 10:16 PM
Bob Onit's Avatar
Bob Onit
That whold idea is quickly becoming something that will most likley not happen....
Im bummed about the whole thing as its just too confusing to me
Old Aug 20, 2006 | 10:18 PM
...Roger...
Bob there are alot of combinations that are good-just ask around -I would go with a kit by someone like Holley
Old Aug 20, 2006 | 10:23 PM
...Roger...
Bob go to Holley.com and look for Systemax Part # 300-503-1 just for fun-its to wild (425HP)but a nice kit-they have ones that are more streetable
