1981 Performance/Emissions
Old Aug 21, 2006 | 04:51 PM
Visine's Avatar
Visine
Cruising
Default 1981 Performance/Emissions
I am in the beginning stages of restoring my new 81 bone stock Vette. This is my first encounter with a Corvette (A/T) and I'm excited. I will be pulling the motor in October for rebuild and I have been hearing that I am about to run into huge problems trying to obtain my goal of 275-300 hp and remain within Texas Emissions standards. I guess its conflicts with CCC and such. To make a long story short.....Is it going to be possible to hit 275-300hp and still be able to pass emission tests? Any suggestions?
Any input greatly appreciated.
Old Aug 21, 2006 | 05:43 PM
Schwee's Avatar
Schwee
Good news! As of January 1, your 1981 Corvette (like mine) is 25 years old and no longer needs to meet any Texas emissions standards.
(At least, it does NOT need to be hooked up to the Machine and measured at Inspection time.)
Old Aug 21, 2006 | 05:52 PM
Kalway's Avatar
Kalway
If what schwee says is true, it's rather simple to convert to a non-computerized setup.
I went to a non-computerized q-jet (I suggest finding a 4MV which start with a 7 in their number instead of a 1). M4M carbs are rated for higher cfm but tuning parts for them are hard to find. A 4MV will bolt right up and once tuned properly will run excellent. You'll also need a non-computerized distributor. I suggest a standard HEI which you can find on ebay for $85 or you can get a well built one from Summit for $120 - $300, depending on what flavor you want. There's no point to using anything besides an HEI unless you plan on winding it up past 7000 RPM. 300hp is easy with that.
Old Aug 21, 2006 | 06:05 PM
Visine's Avatar
Visine
Cruising
Thank you for the input, wasnt wanting to register as an "antique" due to driving restrictions, but I now see it can be registered as a classic which doesnt have the driving restrictions. Computers gettin yanked in October. Thanks again for pointing this out!
Old Aug 21, 2006 | 06:07 PM
Kalway's Avatar
Kalway
If you're yanking it and having it rebuilt, you'll definitely want to bump up the compression. Vortec heads will do you well and probably put you OVER 300hp.
Old Aug 22, 2006 | 04:26 AM
Bangkok Dean's Avatar
Bangkok Dean
How can you put 1981 Corvette & Performance on the same line
Old Aug 22, 2006 | 04:55 AM
Bob Onit's Avatar
Bob Onit
Same way you do with the 73' L-48 ..... Lie
Damn...... I just threw away about 20 of the 4MV's
Someone told my bench was too cluttered...
Old Aug 22, 2006 | 10:41 AM
Schwee's Avatar
Schwee
There's no special registration involved. Any car over 25 years old is exempt from emissions testing in Texas.
Some inspectors might get excited about missing emissions stuff, but if it's clean, you should have no problem.
After I removed the pump and brackets, I cleaned up all the hoses and stuff. For the air pump lines coming out of the top of the exhaust manifolds, I fab'd a steel line, bent cleanly, connecting the two manifolds and running under the air cleaner. Looks good - non functional.
Old Aug 22, 2006 | 06:38 PM
fauxrs2's Avatar
fauxrs2
I dont know anything about inspections in Texas but it is actually against the law to disable or remove emissions gear (wink wink)... if there is still a visual inspection it could possibly pose a problem
Old Aug 22, 2006 | 09:14 PM
a1sensei's Avatar
a1sensei
My '81 walks away from all but the most stout street rods and I still get 18+ mpg. The kicker is, I still use the computer, E4ME carb and computer controlled distributor. I did all the engine/ exhaust mods to get 350-400 HP and was concerned that the carb would run lean, but I'm at 14.7:1 normal driving, 13:1 at WOT. I still scratch my head every time I hear someone tell an '81 owner to ditch the CCC system. God bless, Sensei
Old Aug 22, 2006 | 09:28 PM
SIXFOOTER's Avatar
SIXFOOTER
All ya got to do is read a bit, the CCC is pretty simple. Basically all it does is maintain Air/fuel ratio at idle/moderate throttle. At WOT it runs "Open Loop" and allows the Secondary needles/Jets to do their thing. The carb itself will flow ~650cfm, good for well over 300hp. The CCC will allow higher flowing intake, heads and exhaust and simply adjust F/A according to what the O2 sensor says.
The CCC also controls EGR function, and tranny lockup based on other stuff, but those items shouldn't cause any performance probs.
Old Aug 22, 2006 | 10:23 PM
Kalway's Avatar
Kalway
The thing I hate the most about the CCC system is the ignition timing can't be changed.
The initial timing being the exception.
To 1981 Performance/Emissions
