i still cant find were this ticking is coming from undernieth my passenger door it only dose it when i start or come to a stop then when iam at a complete stop it dose not do it it also gets softer when my tank is more full but still is there all new fuel lines and fuel pump frame off restored 73 somebody pease give me some ideas it is anoying as hell i cant find it thought maybe fuel lines were hitting frame cant seem to find any??????please help
Check out all your exhaust hangers. My pipes used to rattle against the tranny crossmember once in a while, stopped most of it by tightening/moving the hangers around a bit.
You too?
Damn..... It took me a Loooong time to pinpoint that one
I was ready to dissamble the entire car
I heard it most while driving slow along side anything big........ like a building.
Popped the ring off and it was gone
Put the ring back on......... still clicks but at least I know what it is
The blower motor fan in my 81 is loose and rattles in its cage at idle, (probably all the time but you can only hear it at idle). Its right at the pass. side footwell. If it changes pitch or goes away when you speed up or turn on the fan then there you go.
You too?
