Dash lights, what part number ?
Old Aug 22, 2006 | 03:24 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Dash lights, what part number ?
My dash lights are out, my speedo and tach and now all the instruments. Before I go and tear everything apart are these lights readily available at the parts store or are they special GM/Corvette bulbs ?
Anyone know the part numbers ?
I'm gonna put in the new WhiteGauges faces for the speedo and tach while I'm at it, I will post pics when I'm done and if they don't look like crap
Old Aug 22, 2006 | 03:51 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
they're just the standard, get 'em at the auto parts store, push in type light bulb...
Old Aug 22, 2006 | 04:20 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
http://www.sylvania.com/ConsumerProd...lacementGuide/
your welcome!
Old Aug 22, 2006 | 04:31 PM
MotorHead's Avatar
MotorHead
Wow you are quite the internet sleuth, you must have one heck of a **** collection
I think I will be getting the long life version if you have to pull your car half apart to get at them
Thanks guys
Old Aug 22, 2006 | 05:17 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There is one oddball - the bulb at the very top of the center instrument cluster. It has a lens molded in to cast light on the HVAC controls. The parts vendors have them, and I've heard they can be obtained through NAPA.
Old Aug 22, 2006 | 05:41 PM
MotorHead's Avatar
MotorHead
All my lights dash and center cluster lights are out, except for the idiot lights between the speedo and tach ( brake warning etc. ) I can't believe you have to drop the steering column to get at them, any other way ?
Old Aug 22, 2006 | 05:45 PM
Avette4me's Avatar
Avette4me
i've had the speedo and tach cluster out several times without dropping the column. take it all loose and just worm it out..
it does seem a little different that they are ALL out at once though...
Old Aug 22, 2006 | 05:51 PM
MotorHead's Avatar
MotorHead
I had the cluster all loose before and had to put it back in, couldn't get it buy the steering column, amybe and '80 is different ?
Old Aug 22, 2006 | 08:15 PM
7t2vette's Avatar
7t2vette
Old Aug 23, 2006 | 12:33 PM
1Z87L8's Avatar
1Z87L8
as far as i know all 78-82s require dropping the steering column
or you run the risk of damaging the cluster itself.
i have done the whole job of removing the cluster in about
15 minutes as its not really that hard.
bulbs are 168 and 194s and make sure you put them in their
proper sockets.
Old Aug 23, 2006 | 01:18 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: Dashes were installed on the assembly line before the steering column was bolted into its final position. Makes it a little easier to understand why you have to drop the column on some chores, and don't have to on others.
To Dash lights, what part number ?
