Speedo Gear question
You need one to spin faster to make your speedo read "higher", so you want a gear with FEWER teeth.
You'll have to "do the math" to find the right # of teeth.
Chuck
So, you need a 17% change (inverse of 83%)
So, if you have 20 teeth on the current gear, you need 17% fewer teeth.
20 X .17 = 3.4. So, get a gear with 17 teeth (in this example only) Chuck
.83 x 20 = 16.6 or a 17 tooth gear.
Some sites say "approximately" 5 MPH per tooth, but that isn't so, especially with big changes.
You don't say if you have a THM or a manual. THM gears have LOTS of teeth 35-40+. 4 speed gears have less, 18-26 ish as I recall.
Be careful pulling the gear out of a 4 speed. It'll drop back into the tail-stock. You'll hate yourself if that happens, as you'll feel obligated to pull the gear out, and often that's very difficult.
The gears are plastic, BTW.
And, to add to your anxiety,
There are 2 different "drive" gears within the trans. You have to use a driven gear compatible with that drive gear. I'd have to look up the specs. Chuck
lol. It is a 4 speed and if anything can happen to make what i am doing more difficult it always does. So i am sure i would drop that puppy into the tailshaft.
btw the gear goes into the output fitting so you should not have a problem with dropping it into the tail shaft hopefully
A chevy dealer told me a tooth was missing in a gear off the trans end.
I give the dealer a big BS Flag!
Glad I joined this forum!
When I get my garage this fall its *******s and elbows to start gettin my baby in shape!
