New GM fan clutch
Originally Posted by dwncchs
OK who are you? Retired from what?Are you a former GM mechanic?You know too much !!! Ok going back to the 198* I might have screwed up here.I would have sworn those TVS's said 198* on the bottom.I have in my hand what I used to put in to replace it and it says on the bottom 180*- "BUT" the 79 book says the EFE opens at 120* and the 78 book says 180* and the switch I have was actually listed for a 6 cyl.Hmmmm I tried a 120* but it wouldnt allow the choke to come off all the way.But then they went to electric chokes.Hmmm OK Brain is shortcircuiting-time for a nap
BTW..I was just making a joke about the EFE,TVS system operation..had no clue on switch temp.....
Great learning exercise on this forum and I need it....
Originally Posted by rihwoods
No,not a retired mechanic...was engineering specialist in shipyard...trouble shooter on structural failures,vibration,noise, involving everything from main engines to auxiliaries...
Thanks again...think ESU is sawing logs..ZZZZZZZ..but I sent a PM for him to read this thread...
ESU
Originally Posted by ESU
Like 105 for AZ,, 85 for AX.
ESU
ESU
Hmmm they told me cost was 99.75 for AX #343721-new #88961768 and list was 122.84 AX is the lighter duty one of the two
ESU
Looks like a 20 something dollar difference between AZ and AX, wonder why?
ESU
ESU
And that fits with CoolKars information in Post # 9...
1-800-236-2383...btw..
Rich
Just got off phone with Davies Corvette..the fan makes difference..I told him you have a 7 blade like mine...he said "AX" should be ok....
Rich
Rich
ESU
Gotta measure my fan to see what size it is.
#33
Operative word "should" be OK. Since AZ is the "big boy" as DW says maybe that would be better????? Im soooo confuuuuuused!
ESU
ESU
#34
#35
ESU
ESU
Rich
#36
I quoted him exactly so you would examine this choice throughly...I'd feel terrible if you got AX and it ended up taking your new Dewitts rad out...keep hammering for an answer....
Rich
Rich
#37
No AX is the big boy-its about 2" thick ---where the AZ is 1.5" thick isnt that right Rich?
#38
Everyone I've talked to here at home(radiator shop owners,GM tech mechanic,Hayden tech) cautioned me re heavy duty/severe duty clutches versus fan type and fan pitch for those aftermarket clutches....
GM clutch application may just come down to the fan as well...?????
Rich
#39
Post # 28 u said AX is "lighter duty", lighter but bigger?? Now I'm really confused.
"Valve regulates flow of silicone into coupling (of clutch) from a RESERVE chamber".......blah blah...
This has to do with "torque" of fluid on clutch "coupling" up to rotate fan...I think...
Of course,I'm quoting something I read the other day on how these turkey's work....
Rich
#40
Yes...I'm thinking also the AZ operates in a more "forgiving" manner...
Rich
Rich
