63A to 100A alternator?
I'm installing a serp system on my '77, that came from a 1992 Z28. I will be using a CS for sure, and had a crazy idea a few weeks ago. See, I"m deleting the AC and smog. I have delete pulleys for both, but at the last minute decided my many electrical needs would justify a second alt. I have a second brand new CS alt from a good Ebay auction, and want to install it where the AC comp was.
I guess my question is, what the best way to wire in a pair of CS alts to a '77 wiring harness. I already have a line on the plug adapters but what do I do, piggy back them together and beef up the main wiring? I can wire them in parallel right?
P.S. Sorry to thread jack.
I think most dual alternator systems are actually totally separate systems (at least the ones I've seen). What do you have that would max out a CS??!!
Here's something I saw...maybe you need something like this to do the controlling?
http://www.amplepower.com/products/dual_alt/index.html
Thanks for that link...should be what I need. I know that dual alts are used in great amounts in the car audio world where several hundred usable amps are needed at idle.
I have a lot of high amp requirments and things planned for this car. Most alts wil only achieve 60 - 100 amps at idle. You go over that and it's the battery taking the brunt. I want about 200 idle amps available but don't want to spend $500 - $700 for a re-wind alt that won't quite do what I want even. Not to mention I got two spare alts, and one is brand new.
I just want to find a way to make it work right. I like that adapter link you posted...
...and thanks...she's a hotty huh? You recognize her yet?
First off an alternator is a voltage source that is regulated. It produces or attempts to produce a fixed voltage regardless of load current. The voltage is generally set to 13.8v. Lets assume that your first alternator was doing exactly that - 13.8v at the big terminal on the back of the alternator as measured from that terminal to the case. Now you have to understand that the resistance of the wire will produce a voltage drop porportional to the current flowing thru it. So since the voltmeter you observed is not directly connected to the back of the alternator, any voltage drops in the wires that have current flowing thru them will be seen by the meter. So now with nothing turned on in the car you will read very close to the 13.8v. Now turn on the headlights and A/C and current for these devices must flow thru the big wire on the back of the alternator. Well guess what. There is a voltage loss across that wire. And now the meter shows the lower voltage since it is not connected directly to the alternator. This is normal and to be expected. The alternator will still be delivering 13.8v but the wire is loosing some voltage. It gets worse as the wire gets smaller and with the addition of connections. All these connections have resistance and hence a voltage drop when current flows thru them.
So that is whats happening. Do this. Connect a good quality digital voltmeter directly to the back of the alternator. Black to the case and red to the B+ terminal (big red wire). Start the car and everything turned off and read the voltage and then turn on all the electrical consumers you can. Read the voltage again. It will drop a very small amount as compared to the dial guage on your instrument panel. Drop probably in the neighborhood or .1 to .2 volts or so. But your guage will probably show over a 1.5 v drop.
Increasing the alternator capacity to a 100 amp unit wont do anything for the voltage unless the old unit was not able to supply the load. It probably was big enough to do the job. So a bigger alternator is not going to change the voltage drop problem. You will get better voltage regulation from the bigger alternator especially when the RPM is lower but thats it.
Now if your original 63 amp unit was not big enough to do the job, then you should see a major improvement. But since you didn't, I suspect size was not the issue.
Did you look at that adapter? You think that'll work for me? I'm still tracking down a company that makes a dual alt setup for GM trucks with big stereos. They'll have the info I need for sure.
They were a bit vague huh? Did make the point since I will have two regulated alts charging a single source.
I also think it's look pretty cool.
http://www.4alterstart.com/highoutputalternators/
I know all about those sites and their high output alts. They are several hundred more than I want to pay, and their amps at idle are usually the same or less than stock units. They advertise otherwise, but they also test higher RPMs.
Not only that, but I'll be running a serp system, and the pulleys are already undersized. Hard to get smaller.
In another post someone mentioned figuring out who the girl in your photo is but I didn't see who or if it was ever posted.
First I'll say that what she's weraing is not a bathing suit at all...it's paint. All of it.
Also, it was I'm Batman that knows, and I think I told him in a PM.
At a club here last Holloween, there were about fifteen girls that all showed up painted. Most were just topless but one or two of them had NOTHING on. That was frig'n hot man.
Tonic. I'm planning on returning again this year...Heh heh.
The battery will see a slight increase in voltage, but only after the alt runs for a few minutes. The alt will run at teh same voltage for the most part no matter what, unless there is a huge load on it. Just test it at the with both everything on and then off. You won't see much a drop from a healthy alt. Not to mention it shouldn't drop too far under 13V.
I'm in.
There were the painted girls, and the rest had on some form of underwear or lingerie formed into a costume. I remember this one hotty who was a football ref. Her skirt was so short it was more like a belt. Had the long white stockings on, and cute little black school girl shoes...
*Takes cold shower.*
