1969 and 1970 Muncies had a plastic drive gear held on with a clip on the mainshaft. They fit poorly and fall off all the time, resulting in one having to remove the tail to stick it back in place. I prefer the press fit drive gear.
For what its worth you don't need a puller unless you are just changing the speedo gear. Remove the rear snap ring and just press the whole thing off in one shot from 2nd gear all the way up.
Heat the new gear up on your stove and slide it into place.
I need to know the part number for the muncie speedometer gear for my 1969 corvette. please tell. Add details for this "not knowing" mechanic. thanks Ed
