E4ME question
Old Aug 22, 2006 | 10:38 PM
ss_slayer's Avatar
ss_slayer
Default E4ME question
ok, maybe this could sound like a dumb question but anyway here it goes, when should the secondary throttle should open completely? mine just opens a little bit at full throttle, is this normal?
Old Aug 22, 2006 | 10:56 PM
SIXFOOTER's Avatar
SIXFOOTER
you are not going to be able to get them to open in the driveway
Old Aug 23, 2006 | 12:28 AM
BigBlockk's Avatar
BigBlockk
Are you talking about the secondary throttles or the air valve?
BigBlockk
Later.....
Old Aug 23, 2006 | 01:06 AM
Bob Onit's Avatar
Bob Onit
Also, with the engine running or turned off?
Old Aug 23, 2006 | 09:40 AM
ss_slayer's Avatar
ss_slayer
BigBlockk
Later.....
the air valve including the choke valve, they just open a little bit, and the engine is running
Old Aug 23, 2006 | 01:56 PM
Kalway's Avatar
Kalway
You can't make them open when it's in neutral. They only open when the engine actually has a load on it, at the point it needs the extra air/fuel.
Old Aug 23, 2006 | 07:52 PM
Bob Onit's Avatar
Bob Onit
Thats why I had asked if the engine was running or off
You can make sure all linkage is working with the engine off.;;
Old Aug 24, 2006 | 10:55 AM
ss_slayer's Avatar
ss_slayer
thanks for the help!!!
Old Aug 24, 2006 | 01:16 PM
BigBlockk's Avatar
BigBlockk
The choke should be all the way open if the engine is warmed up. Unless you have a whole bunch of engine, you'll never be able to get the secondary air valve all the way open. The engine simply can't use that much air.
BigBlockk
Later.....
Old Aug 24, 2006 | 02:43 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
BigBlockk
Later.....
Even under load, a stock engine won't open it all the way. This carb will support considerably more HP than these engines put out.
To E4ME question
