Under Carpet insulaltion
Old Aug 23, 2006 | 10:52 AM
11Jake's Avatar
11Jake
Default Under Carpet insulaltion
Need Advice:
I am replacing my carpet in my 80 vette and is like any other vette, hot as h@ll inside the cabin. I read all the treads for advice and going to put a shutoff valve on the heater hose. I also want to put the heat resistive carpet underlayment like dynamat. My question is what thickness carpet underlayment and what kind should I use that will fit under the carpet like the original jute underlayment that will still let the carpet fit properly?
Old Aug 23, 2006 | 11:55 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
I just had my carpet redone in my 82. I just bought the pre-cut kit for mine......the installer never complained.....so I guess, it fit ok. It was the insulation with foil on both sides.
Larry
Old Aug 23, 2006 | 12:00 PM
sfallison's Avatar
sfallison
You can check out this site:
http://mywebpages.comcast.net/vettfixr/page14.htm
I used the HVAC insulation (foil bubble-wrap type) from Home Depot. No problems with thickness when installing my carpet.
To Under Carpet insulaltion
