Driver Side Speaker
Old Aug 23, 2006 | 12:34 PM
75BrownC3's Avatar
75BrownC3
Default Driver Side Speaker
What is the best way to replace the drivers side speaker? I tried to do this last weekend trying to take the instrument cluster out but it looks like you have to remove most of the steering column. Any ideas?
Old Aug 23, 2006 | 01:14 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What year? Are you talking about the dash pad speakers? If memory serves, they come out from the top.
Old Aug 23, 2006 | 01:18 PM
75BrownC3's Avatar
75BrownC3
In a 75 and it is the dash speaker.
Old Aug 23, 2006 | 01:32 PM
sfallison's Avatar
sfallison
You don't have to remove the column.. Just remove the instrument cluster. You will have to remove the plastic collar around the steering column(at the dash), and unscrew the instrument cluster. It's a Pain in the A$$, but do-able. Just be careful pulling the cluster out - Remember to disconnect the speedo cable first!
Old Aug 23, 2006 | 01:46 PM
75BrownC3's Avatar
75BrownC3
I guess that is where I was going wrong. Got used to the new cars with the electronic speedo I forgot all about that cable.
Old Aug 23, 2006 | 01:48 PM
big_G's Avatar
big_G
I would pull the dash pad, not the cluster. Remove the pillar trim pieces, the screws that hold the speedo/tach. cluster and right side map pocket panel to the dash, and the 1 screw at the top of the center gauge cluster. Remove the right map pocket/pad. There may be a dash pad support bracket behind it. Carefully remove the dash pad, tilting it as necessary. IMO, alot easier than F-ing with the speedo/tach. cluster.
Old Aug 23, 2006 | 02:04 PM
Durango_Boy's Avatar
Durango_Boy
This is how I first did it many years ago in my '77. Much easier. You will have to wrestle the dash pad a little to gt it out so be careful you don't hurt it.
Old Aug 23, 2006 | 02:08 PM
75BrownC3's Avatar
75BrownC3
Are there any clips underneath the dash pad to look out for?
Old Aug 23, 2006 | 02:10 PM
Durango_Boy
The leading edge under the glass has a lip that slides under the dash frame so it can't pull up without first coming out a little.
The only other fasteners are the screws that hld the left and right sections to the upper pad, and the gauge cluster bezel.
Old Aug 23, 2006 | 02:44 PM
75BrownC3's Avatar
75BrownC3
I'll have to try that out this weekend. Thanks for all the tips.
Old Aug 23, 2006 | 02:55 PM
Durango_Boy
What are you replacing it with? I am fairly skilled at car audio too. If you're keeping a stock or better HU and you install better speakers you will get poor sound quality. Better speakers must be amped. If you don't feel like amping the speakers, then make sure you find some replacement speakers that are only 15 - 25W RMS. If they're much higher than that the sound will be worse than with the old crappy speaker.
Old Aug 23, 2006 | 03:02 PM
75BrownC3's Avatar
75BrownC3
Nothing can be worse than the old crappy ones because the just don't work at all. I replaced the passenger side one lasy weekend, that was a piece of cake. These are supposed to be direct replacements from Mid-America. The magnets are bigger than the one I took out. I am keeping the stock HU because I want to keep the car as original as possible. I was thinking about adding my XM Roady with the inline FM modulator but not sure where to put the XM antenna since it is magenetic. I do have a T-top so I can fish the antenna wire through that if needed. It is the AM/FM mono radio in there now.
Old Aug 23, 2006 | 03:06 PM
Durango_Boy
OEM style speakers should be fine. Good luck with that speaker.
Old Aug 23, 2006 | 09:01 PM
75BrownC3's Avatar
75BrownC3
Thanks.....
Old Aug 23, 2006 | 11:05 PM
Durango_Boy
No problem, just keep us posted on how it turns out or if you have any other problems.
Old Aug 24, 2006 | 08:11 AM
Chuck-75's Avatar
Chuck-75
I just removed the dash in My 75 vert last week. (Im redoing the heater core,then anoughter an anoughter,project always comes along?)
anyway-the drivers side lower pad is the worst. after you remove all the screws that are on the front. and lower the steering colum, then disconnect the speedo cable under the car(mine has a 2 cable system,not just one long cable) and I had to push a little of the cable into the firewall. then you can pull gently on the pad and give yrself enough room to unbolt the speedo and the tack.
also dont forget to remove the milage cable under the dash and after you get enough room on the inside of the upper left hand corner to release the head light ****,then undo the head light swich.
from there you can see the speaker and replace it.........
damn makes my tired just typing this. lol
good luck.
Old Aug 24, 2006 | 10:11 AM
Durango_Boy
Again, why mess with all that when the dash pad will come off without removing the dash panels? Just remove all the screws, a-pillar trim, and worm it out. Change the speakers, and slide it back in. Re-install screws, and play the music.
To Driver Side Speaker
