? on 350hp cam
Part # 967601
.050 int. dur. 222
.050 ex. dur. 222
LSA 114
lift int. .447
lift ex. .447
comp ratio 8.75-10.75
power range 2000-5600
How about a modern cam ??
Crane Z-cam
cam and lifters part # 113522
.050 int. dur. 218
.050 ex. dur. .230
adv. int. dur. 268
adv. ex dur. .280
LSA 112
lift int. .459
lift ex. ..486
power range 1800-5800
With an .050 int. dur. of 218 and a 112 LSA you
will have plenty of vacuum
very good. I think you would like the Z/cam.
Crane cams energizer
cam and lifters part # 100172
.050 Int. dur. 218
.050 ex. dur. 218
adv. Int dur. 274
adv. ex. dur. 274
LSA 106
lift int. .450
lift ex. .450
power range 1800-5400
This cam will pretend to be a big racing cam at idle but is
just a mild cam
Get a real cam. That Z cam or maybe a comp XE268. Decent cams for mild motors. I think the XE268 is 224/228, .474/.490 on a 110lsa. I just installed that cam in a .040 350 but have not got it running yet. You need headers on it if you don't have them.
If you want more lope from an aftermarket cam you can generaly look for tighter lobe centers. For example most Comp Cams grinds are in the 110 degree LC range so they tend to lope more than these stockers that typicaly run closer to 114 degree lobe centers. Don't get too caught up in the lift and durtation comparisons between stock and aftermarket. They are not easily compared because the published GM numbers were not measured the same way and they are not ground anywhere near the same as typical aftermarket specs.
-Mark.
The baseline l-48 cam retarded 4 degrees makes for a decent running engine and low end torque when combined with 9.75:1 SCR max, however it won't have your drive-in lope.
If you are just after a cam to make noise and not yield gobs of low end torque then your basic cam ground on 110 centers is for you.
Summit offers a couple very decent cam kits like their SUM-1103 and SUM-1104 that will fit your bill.
Crane Cams phone # 386-258-6174 Fax 386-258-6167
Crower Cams Phone # 619-661-6477 Fax 619-661-6466.
Isky
Comp Cams
The Vortecs have smaller combustion chambers so just do your math before shopping for a cam. With a 3.08 rear end, you are going to want something that will provide you with some good low end torque.
-Mark.
DANA CLEVITE manufactured & supplied many of the OE cams to GM; still do AFAIK. I’ve pulled many OE motors apart & find raised DANA “elongated diamond” logo cast between lobes. They’re still in business in a big way and provide OE & replacement cams for virtually anything w/ pistons & at least 4 wheels. Following are DANA CLEVITE crossover #’s & cam specs:
(aka L48)
GM 3896929 = 229-1274
SAE 260/271, 0.050” 194*/203*, vl .390”/.410”, icl 108*, ecl 116*, LSA 112* (intake close 25* ABC)
(aka 327-350)
GM 3863151 = 229-1713
SAE 290*/290*, 0.050” 223*/223*, vl .447”/.447”, icl 110*, ecl 118*, LSA 114* (intake close 42* ABC)
(aka L82)
GM 3896962 = 229-1990
SAE 291*/287*, 0.050” 224*/224*, vl .450”/.460”, icl 114*, ecl 114*, LSA 114* (intake close 47* ABC)
