sneaker change
Old Aug 24, 2006 | 08:30 AM
Tina69's Avatar
Tina69
Default sneaker change
Hey starting to consider a tire change. What are you running and how do they handle. 69 4spd.
Old Aug 24, 2006 | 11:24 AM
Durango_Boy's Avatar
Durango_Boy
I have a set of Yokohamas on my '71 Charger and I love them. I'll look up the rubber number in a bit and post that.
My Vette has Goodyears, but they are older and discontinued. I will probably get Goodyears again, but the new kevlar layer tires.
Old Aug 24, 2006 | 12:28 PM
pws69's Avatar
pws69
I have been "considering" the same for 2 years now! The problem is that there are VERY limited choices for our stock rim size these days. Most people choose 245 or 255/60R15. Many go with the BFG's that you have now (VERY nice lake, by the way) with Goodyear Wide Ovals and Firestone Firehawk's following up. Some have tried and liked Yokohama AVID S/T - even though it is listed as a "truck" tire. Tire Rack is a good online place to see what's available.
Old Aug 24, 2006 | 01:23 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
255/60/R15 Firestone Firehawk Indy 500s. I like them, then seem to handle pretty well in both dry and wet conditions.
Old Aug 24, 2006 | 01:32 PM
Durango_Boy
Carefull about a blowout...you could flip your Vette and have to sue Firestone...
My Charger has Yokohama Avid V4S tires. I love them.
Old Aug 24, 2006 | 04:35 PM
70 LS1's Avatar
70 LS1
Are you wanting stock sizes or something different?
Old Aug 24, 2006 | 04:47 PM
NHvette's Avatar
NHvette
For stock 15" rims, I would opt for the Firehawks as well.
Fairly cheap and overall best customer rating.
Plus, they look good.
Me, I have switched to C5 rims (17",18"). Can't comment on handling -
only been up and down the driveway for now.
Old Aug 24, 2006 | 05:15 PM
Durango_Boy
Did you change the suspension too or just adapt the stud pattern? How did you get them to fit?
Old Aug 24, 2006 | 05:19 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Firestone fixed the car tire problem after the 500 recall in the mid-70s. The truck tires...well...that's a different story.
Old Aug 24, 2006 | 05:20 PM
Durango_Boy
Yeah I was kidding. I loved the tread design on your tires. Very all-weather for sure, and from the look, high shoulders, you will likely have a minimum of road noise once you get the suspension back together.
Old Aug 25, 2006 | 04:28 PM
NHvette's Avatar
NHvette
All stock C3 suspension (except aftermarket rear sway bar).
Stud pattern is the same, but you need 3" adapters to compensate for the different offset.
More views (and assorted opinions) here:
http://forums.corvetteforum.com/show....php?t=1341764
Old Aug 25, 2006 | 04:33 PM
Durango_Boy
Okay, I like the look, and the 3" spacers are fairly easy to get for me. Question, will the C6 wheels mount up the same way as the C5s? I almost like them better and have a line on a set.
Old Aug 25, 2006 | 07:21 PM
jlaw68's Avatar
jlaw68
i just put on a set of BFG radial t/a and i really like them so far. just had to wait a week for them to be ordered and come in. and i like the look of the white letter tires.
Old Aug 25, 2006 | 07:36 PM
Durango_Boy
How well are they expected to handle in wet weather...in case it's driven like that?
Old Aug 25, 2006 | 09:21 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
ANyone tried these tires, they are V rated over 130MPH ?
Pirelli Scorpion Zero - 255/60VR15 @ $115 ea.
Old Aug 25, 2006 | 09:22 PM
Durango_Boy
I had the Zeros on a 300ZX I used to drive. I loved them but they wore fast for my tastes. May have been an older model too.
Old Aug 25, 2006 | 09:42 PM
ajrothm's Avatar
ajrothm
Here is mine the day I put new tires on it. 245/60 BFGs on the front and 255/60s on the rear:
To sneaker change
Old Aug 25, 2006 | 10:07 PM
Durango_Boy
Clean man...very clean. I like the look a lot. Great stance. What year and drivetrain?
Old Aug 25, 2006 | 11:22 PM
jlaw68's Avatar
jlaw68
well im not running the slolom course in the rain but they handle as well as can be expected. and for the most part i dont drive it in the rain, i have a truck to drive for the bad weather.
Old Aug 25, 2006 | 11:45 PM
Durango_Boy
Me too, I only ask because the tires i used to have on the Vette were great on dry, but on wet, at a light, when I gassed it I would spin and spin and spin. It kinda sucked. I now have some great Goodyears but will need to upgrade in the next year or so.
