edel brock Carb ID
Old Aug 24, 2006 | 11:44 AM
Disco_Mike's Avatar
Disco_Mike
Default edel brock Carb ID
I purchased an Edelbrock carb from Ebay.
It works ok, but needs to be rebuilt/rejetted/ tuned.
How do I find the 'Series' of carb it is?
Thanks!
Old Aug 24, 2006 | 12:17 PM
Durango_Boy's Avatar
Durango_Boy
Thanks!
Where were you going to buy the rebuild kit?
To be honest, instead of looking around for the deff of the casting numbers, just take the carb with you to Oreilly. They will punch one of the numbers in, and give you the right kit.
Then you can just ask him, and kill two birds with one, very big stone.
Old Aug 24, 2006 | 12:19 PM
1970-Bronze's Avatar
1970-Bronze
It's stamped on the Carb - I think on one of the front base plate tabs.
Old Aug 24, 2006 | 12:22 PM
Durango_Boy
There are usually up to three numbers stamped into the body of the carb. Make sure you write them all down if you don't opt to just take the carb with you.
Old Aug 24, 2006 | 12:24 PM
1970-Bronze
Your looking for a 4 digit number and it should start with 14xx........sorry I should have added that to my post.
Old Aug 24, 2006 | 12:31 PM
Durango_Boy
The common two are 1406 and 1407. One's electric choke, the other is manual. Both I think are 650s.
Old Aug 24, 2006 | 12:40 PM
Disco_Mike's Avatar
Disco_Mike
Im fairly certain it is a 1406. the only numbers I saw stamped were '8828'
So I can go to any big chain and they can get the numbers?
Just got back from playing with it.
Everything runs ok except the idle needs to be are 2000 or it stalls.
when I partically cover the air horn with my hand, the idle go up.
Im thinking that I just need to rejet. but I might as well rebuild it while I am at it.
Old Aug 24, 2006 | 12:48 PM
Durango_Boy
Yup, they can enter the 8828 into their database, and look up the correct part number without even needing the carb model number.
What enigine is this going on? Stock? Modded?
Old Aug 25, 2006 | 02:17 AM
Disco_Mike's Avatar
Disco_Mike
a L82 that is stock except for long tube headers and dual exhaust.
My Q-jet needed some work and the parts are fun to try to find.
Old Aug 25, 2006 | 11:29 AM
Durango_Boy
Have you thought about a whole new carb? Maybe a new series Demon? I hear wonderful things about them.
To edel brock Carb ID
