drops of coolant...
Old Aug 24, 2006 | 02:50 PM
panic's Avatar
panic
Default drops of coolant...
hi, i need an advice here:
there are, when i stop the car and the engine is nice and hot, some drops of coolant falling from the right side just on the tire side closer to the door...it goes right on the hooker side exhaust right manifold. now, i've checked the upper and lower rad hoses (which are new) and the alu rad (which is pretty new too) and everything is well tight, the rad screw is new and perfect...but those drops are there, just a few, but enough to drive me nuts.
also, i think the cruising temp has rised fm the usually and healthy 160/170 max to just under 200...
what's your opinion? thanks/Giu
Old Aug 24, 2006 | 03:17 PM
Durango_Boy's Avatar
Durango_Boy
Can you post some pics of where you mean? I'm a little confused.
Old Aug 24, 2006 | 03:45 PM
panic's Avatar
panic
I WILL TOMORROW, THIS IS A GOOD IDEA...
Old Aug 24, 2006 | 03:46 PM
Meh's Avatar
Meh
Overflow bottle? Heater core?
Hauq`'s Avatar
Hauq`
Sounds like the area where the heater hoses run. Do you still have the heater hooked up? You should also look at the vacuum valve for a leak.
Old Aug 24, 2006 | 03:50 PM
BerniesVette's Avatar
BerniesVette
Did you check your heater hoses, shutoff valve and where they connect to firewall? Try tightening them. I had a leak on my overflow canister. Your leak could be there or on the hose that runs from the rad to the canister. My canister was cracked.
As for the sudden temperature change. If it is the canister, then your radiator may be low on fluid. Just a thought. Next thought would be the t-stat sticking. But I would check coolant level first.
Bernie
Old Aug 24, 2006 | 03:51 PM
Durango_Boy
Yeah, I was waiting for the pics, but I think maybe where the heater hoses go into the core are where the drips are originating.
Old Aug 24, 2006 | 03:55 PM
panic's Avatar
panic
hi you2..bottle is at one third when cold, right on the sign that shows 'cold'...and i have no heater, my engine bay is very raw, simple and streight, all ancillaries surpluses (heater/ac/etc) has been taken away, and i see no sign of any malfunction around it...tomorrow i'll post a pic and you'll where is falling the damn drop...thanks
Old Aug 24, 2006 | 04:00 PM
BerniesVette
Have you looked for white spots on the rad? It could have a pin hole and the fan could be blowing it to that area.
Bernie
Old Aug 24, 2006 | 04:02 PM
Durango_Boy
Bernie
Wouldn't that make more of a splatter than anything else?
Old Aug 24, 2006 | 04:11 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I bet it's coming from the overflow bottle somehow, maybe it developed a leak
Old Aug 24, 2006 | 04:15 PM
Durango_Boy
There has to be a sign somewhere for leakage though besides the drip on the header.
Old Aug 24, 2006 | 05:25 PM
rihwoods's Avatar
rihwoods
Very possible it is overflow bottle..if plastic,run you hand down underneath it (engine warm) Sometimes they leak at seam....or,weep at cap...Would not think a freeze plug is leaking/spraying from your fresh motor...but worth a check also...
Rich
Old Aug 24, 2006 | 06:13 PM
panic's Avatar
panic
thanks guys, i'll summarize all your tips and advices and will check the car early tomorrow, then i'll post pics, thanks/giu
Old Aug 24, 2006 | 06:19 PM
Durango_Boy
We'll be here...staring at my avatar.
Old Aug 24, 2006 | 06:38 PM
rihwoods's Avatar
rihwoods
Paint won't rub off.....
Margarita time....adio's...
Old Aug 24, 2006 | 06:39 PM
mirrorfinishman's Avatar
mirrorfinishman
Sounds like it could be the heater shut-off valve.
It is possible that the heater shut-off valve could be leaking when it is in the 'heater off' postion. Try running it in the 'heater on' position and the temp dial turned all the way down. If you no longer see any drops of coolant, that's the problem.
To drops of coolant...
Old Aug 24, 2006 | 06:44 PM
Durango_Boy
I think he removed the heater core and components.
Old Aug 24, 2006 | 06:59 PM
mirrorfinishman
After re-reading his posts...now I see. No heater. No need for a heater shut-off valve. Thanks for the heads-up!
Old Aug 24, 2006 | 10:58 PM
Durango_Boy
Also cuts down on the places the fluid CAN leak from. Took out a lot of weak spots. Seems like the only fluids are moved between the engine and radiator. Anywhere further back it's from the block. Confusing without pics, so I'll wait for some of those.
