Forged crank damaged. Options: new engine??
Old Sep 9, 2001 | 05:10 PM
BLT-71's Avatar
BLT-71
Default Forged crank damaged. Options: new engine??
Well I took out the engine and took off a rod and found the bearing had broken and a part of it is welded to the crank and the crank has a good gouge out of it.
So I was looking at a new forged crank 500-600$. With the rebuild and everything else I can just about buy a new short block.
If anyone has a suggestion on a short block to buy or ideas of a next step that won't break me.?
Old Sep 9, 2001 | 05:58 PM
redvetracr's Avatar
redvetracr
Default Re: Forged crank damaged. Options: new engine?? (BLT-71)
BLT-71,
You may be able to get that fixed, The ad might of been in "Hot Rod" magazine as i remember their logo said "If it isn`t broken we can fix it"
...redvetracr
Old Sep 9, 2001 | 09:24 PM
LT1driver's Avatar
LT1driver
Default Re: Forged crank damaged. Options: new engine?? (redvetracr)
Take it to the machine shop, any good one should be able to fix it up. By the way how do the hookers fit ( what size) . Good luck on the rebuild. :seeya
Old Sep 9, 2001 | 09:38 PM
BLT-71's Avatar
BLT-71
Default Re: Forged crank damaged. Options: new engine?? (LT1driver)
The Hookers fit fine. They are Comps not Super Comps so bolting them up is easy and the fit is perfect.
The only flaw is the collector flanges are not flat side down. They are just turned enough to catch speed bumps on rare occasions.
To Forged crank damaged. Options: new engine??
