Needle scaler for removing rust?
Old Aug 24, 2006 | 11:35 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Needle scaler for removing rust?
http://www.northerntool.com/webapp/w...70_12817_12817
Anyone ever used one of these? Think it would be good for rust removal, or too violent? Saw it while browsing NorthernTool, never heard of one before.
-Chris
Old Aug 24, 2006 | 11:38 PM
comp's Avatar
comp
a little to much for most auto job's my .02
Old Aug 24, 2006 | 11:43 PM
SIXFOOTER's Avatar
SIXFOOTER
It woll work, but will work you too. What ya got rusted, chemical might be better
Old Aug 25, 2006 | 12:05 AM
noonie's Avatar
noonie
-Chris
Good idea. Never thought of that before. They work great of weld scale.
Old Aug 25, 2006 | 12:12 AM
jd1a's Avatar
jd1a
Used one many years ago taking off thick rust off 1/2' thick plate. Worked well there, becareful on a frame.
Old Aug 25, 2006 | 12:44 AM
LiveandLetDrive
I don't have too much rust, just curious. Might pick one up for welding projects use...
Old Aug 25, 2006 | 08:20 AM
wartosh's Avatar
wartosh
Used one in the NAVY, works great for removing paint. Doesn't do much for thin sourface rust. Use a wire wheel or sander.
Old Aug 25, 2006 | 08:31 AM
76greg's Avatar
76greg
I have one that I got from Harbor Freight. It fits on the end of the air chisel they sell or you can get the all in one unit. Go to www.harborfreight.com and search on scaler.
Here is the direct link - http://da.harborfreight.com/cpisearc...keyword=scaler
Greg
Old Aug 25, 2006 | 08:52 AM
sfallison's Avatar
sfallison
I used one in the Navy too.. Taking rust of deck plates! Too much for a car.. it will leave mini-dents in the metal!
I use a drill attachment wire wheel, and an electric grinder with 80 grit disks for getting rust off the undercarrage.
Old Aug 25, 2006 | 09:03 AM
bahamasair's Avatar
bahamasair
They are mainly used for removing the slag on welds. Wire brush on a drill works best for me unless you want it to look new then you will need to sand blast which frigging sux.
To Needle scaler for removing rust?
