Turn on headlights, engine dies
Old Aug 25, 2006 | 05:18 PM
RodTeq's Avatar
RodTeq
ToolMan
Default Turn on headlights, engine dies
I have a 1970 350/350, 11:1 with stock Qjet carb. Bought this low mileage car in February and like others on the Forum, my headlights opened and closed on start-up and my windshield wiper door remained open.
I replaced a bad check valve, a wiper relay and the wiper circuit works correctly now.
Determined the headlight relays were loosing vacuum and replaced them today with new ones from Ecklers. When I turn on the headlights, I have no low beams, the headlights will not go up, the mechanical over-ride under the dash will not raise the headlights AND at idle, the engine dies when I turn on the lights!
I expect a vacuum leak somewhere and I have removed the headlight switch. The blue stripe hose between the switch and the mechanical override appears good.
How can I check out the headlight switch? Could the "new" relays both be bad? I am stumped.
Old Aug 25, 2006 | 06:46 PM
Duke94's Avatar
Duke94
Here's the schamatic if it helps. Obviouly you have a massive vacuum leak downstream of the light switch. Start by checking for bad/loose hoses under the dash.
Old Aug 25, 2006 | 09:11 PM
Sayfoo's Avatar
Sayfoo
Sounds like 2 problems. Vac leak and elect. problem--no low beams. Dimmer switch? You'll just have to trace the wires and check for voltage as you go along. Obviously, check easy things first. Sockets, bulbs, broken wires. Good luck
Old Aug 25, 2006 | 10:51 PM
RodTeq's Avatar
RodTeq
ToolMan
Thanks, will get into wiring and hoses tomorrow...
Saturday update, found one headlight relay was bad, the other sticking. Car won't start, appears the carb is flooded.
Old Aug 26, 2006 | 10:24 AM
jbs75's Avatar
jbs75
Check for engine ground strap first. That will cause all kind of squirrelly symptoms.
Jim
To Turn on headlights, engine dies
