What Is the best composite spring made??
Old Aug 26, 2006 | 12:08 AM
sharkman76's Avatar
sharkman76
Default What Is the best composite spring made??
I see alot of forum members running composite rear springs and I want one! I also see several differant brands, styles (TRW) and rates! How is a guy suspossed to make up his mind like that! So I'll ask you guys who likes what and why? and what about a shorter spring for tire size?
Old Aug 26, 2006 | 12:33 AM
rihwoods's Avatar
rihwoods
Not TRW,that's for sure... In fact,I gave mine away....
Old Aug 26, 2006 | 01:01 AM
sharkman76's Avatar
sharkman76
I've heard that before about the TRW's I hope some owners chime in on this before the money burns a whole in my pocket
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Go with VBP
Old Aug 26, 2006 | 01:59 AM
sharkman76's Avatar
sharkman76
Any one goy pics?
Old Aug 26, 2006 | 07:55 AM
w1ctc's Avatar
w1ctc
I have the TRW spring. I got the 315 LB version. The ride is nice but should have gone one step harder. The real problem was ride height. Sits too high without stupid long bolts. There was a super long thread about this problem a few years ago. Pictures of spring bolts hanging where a flat tire would have them hitting the ground (bad things would happen if at speed). Some guys had the same problem with the VBP spring, others had no problems with eather spring. This was 2 years ago and don't know what the situation is now. They do not break in and get lower over time and you must get the right shocks or it will bounce around like crazy.
Old Aug 26, 2006 | 08:01 AM
Gordonm's Avatar
Gordonm
I had a VB spring for a number of years with no problems. I have sold it to a forum member and it now rides under his car with no problems. I have now installed a custom 415# shorter by 1 inch either side on my car from VB products. I can recomend them and they have been very helpful. I even stopped by this winter and checked out their facility.
Old Aug 26, 2006 | 08:46 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
VBP or Vansteel can probably hook you up quite well. Links are on the side bar.
Old Aug 26, 2006 | 10:08 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Mine is a VBP 330 or something like that. Might even be a little lighter. It was on the car when I got the car and I have had the car for at least 6 years now. No problems with mine.
Old Aug 26, 2006 | 10:13 AM
vho69's Avatar
vho69
Originally Posted by SHAKERATTLEROLL
Go with VBP
Old Aug 26, 2006 | 11:46 AM
sharkman76's Avatar
sharkman76
sounds like VBP is winning the race I am thinking #330 lbs! Do I have to replace bushings on the cross member? I am running a new set of monroe sense-a-tracks now I hope they are compatable!
Old Aug 26, 2006 | 12:07 PM
rihwoods's Avatar
rihwoods
Here are pictures of my old TRW composite..from receipts I got with vette,it was 12 years old when I changed to a Guldstrand steel 7 leaf...believe the TRW was a #330....
Rich
Old Aug 26, 2006 | 12:18 PM
sharkman76's Avatar
sharkman76
rihwoods what was your dislike? You went back to seel isnt the up grade to go the other way?
Old Aug 26, 2006 | 12:39 PM
theandies's Avatar
theandies
VBP 330# here. Love it. Very nice ride, not as harsh as my old steel spring (but it was worn out so that may have been the problem). Handles well and I don't have the ride height problem. I did come with the 8 in bolts though. The bolts are no where near my tires.
Old Aug 26, 2006 | 12:41 PM
rihwoods's Avatar
rihwoods
My Guldstrand was an "upgrade" over a stock steel spring...shorter by 1 1/2" and stiffer by about 50#....
On your question:
The TRW had a weird sort of "lope" or "bounce" when hitting bumps at speed...something I never experienced with my 78 FE7 steel spring...in fact,it made me unconfortable also considering the torque of the 69 502...that all went away with the Guldstrand steel 7 leaf...
VBP from my readings here is a quality company and product,and they back it up...so you need input from those who run them on the forum...
I just prefer the steel version...
Rich
Old Aug 26, 2006 | 12:50 PM
Guru_4_hire
Cruise-In V Veteran
I did just dedicate a large quantity of money to VBP parts. I have come across few companies that have such a positive reputation.
Old Aug 26, 2006 | 01:12 PM
rastadr's Avatar
rastadr
i spent a lot of time wavering back and forth on what rate spring i would get for this car and finally decided that the adjustable dual mount spring sounded good for its adjustability.. i did good. it truly only takes 10 minutes to adjust it and ive been at 3 settings so far. its on the second to firmist now as it performs at the track (1/4) the best. it definately handles curves and exit ramps superiorly at two settings softer than it is now and once i dip into the 11's (11.99 would be nice) ill go back to a cushier ride) either way i prefer to buy my vbp stuff from the dad and son team at Vansteel. they are more personable and when they advise you on a product it is from true hands on experience, not from what they read in a catalogue.
To What Is the best composite spring made??
Old Aug 26, 2006 | 03:13 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
VB&P is probably my favorite vendor. Not only do they have great stuff, they have the best customer service of any company I've ever encountered.
I'm installing a dual-mount right now. I can't say I agree with your characterization of VB&P, they've been nothing but friendly and helpful with me. Van Steel is another great organization, though...both are complete class acts.
Old Aug 26, 2006 | 05:10 PM
shafrs3's Avatar
shafrs3
It was a close race but I went with the TRW 340# just because TRW springs come with a heat shield. I've since shortened it by 1-1/4". I've had no problems with it, has a nice ride and I've had it for 8 years. It did require long bolts to adjust the ride height.
Old Aug 26, 2006 | 05:45 PM
Tankers's Avatar
Tankers
How did you shorten the spring and did you have to use the 8" bolts
