Solid Mounts
Old Aug 26, 2006 | 08:51 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Solid Mounts
Any benefit or drawbacks to solid motor and tranny mounts?
Old Aug 26, 2006 | 09:15 AM
uhvette's Avatar
uhvette
Default mounts
I had to use them, I installed the stock mounts with my 385 and the first time I barley touch the gas broke the mounts and punched a small hole in the heater box (thats torque!). Tends to be a bit more vibration with the solid mounts....you can try to cut down on this by using urethane mounts.
Old Aug 26, 2006 | 10:16 AM
BerniesVette's Avatar
BerniesVette
One benefit of the solid mounts is that it stiffens the front frame of the car; keeping it from flexing as much.
Bernie
Old Aug 26, 2006 | 10:20 AM
Guru_4_hire
Cruise-In V Veteran
Coolio
Old Aug 26, 2006 | 10:26 AM
Twin_Turbo's Avatar
Twin_Turbo
don't use solid mounts on the engine and trans, leave the trans a normal one, otherwise you may crack the tranny case.
Fevre's Avatar
Fevre
I am running a poly one the driver side and rubber on the passenger side, the eng barely moves when you get on it but does not vibrate at idle with a slightly lobey cam since the rubber side absorb the vibration
Old Aug 26, 2006 | 10:56 AM
Guru_4_hire
Cruise-In V Veteran
I dont mind vibrations. Its a sports car.
Old Aug 26, 2006 | 11:58 AM
norvalwilhelm's Avatar
norvalwilhelm
Bernie
I agree. I resisted solid mounts because of the vibration at idle but I also wanted to stiffen the front frame up especially around the steering box so I went solid. I honestly don't notice a vibration and wished I had gone the solid route years ago.
Like Twin Turbo said don't go solid on the tranny mount. I left mine poly.
Old Aug 26, 2006 | 12:11 PM
Guru_4_hire
Cruise-In V Veteran
Thanks norval that sounds like the best way to go.
To Solid Mounts
