matching numbers
Old Aug 26, 2006 | 07:57 PM
clintwilson's Avatar
clintwilson
Default matching numbers
just bought 1st vette.1980 red 4 spd. vin#1z878as413556. front block#v1213zam & 1s413556. rear block#14010207. question.matching#or not.
Old Aug 26, 2006 | 08:12 PM
chevylit's Avatar
chevylit
The block is indeed original to the car but there are a lot of other
numbers to check to see if You have a "matching numbers" car.
Casting numbers on heads,intake manifold,exhaust manifolds,numbers
on carb,alternator and on and on. That being said You have a good
start with the orig. block.
Old Aug 26, 2006 | 09:56 PM
clintwilson
Default matching #
thanks for confirming that. will start checking other #s . will they match vin. production dates. or what. 54000 miles solid frame looks clean.underhood looks untoutched exept water pump. thanks again.
Old Aug 26, 2006 | 10:54 PM
SmokinBBC's Avatar
SmokinBBC
You wil need to get a book to verify the numbers. The engine and transmission have the partial vin stamped in them.
I have "Corvette by the Numbers" by Alvin Colvin. Great book.
To matching numbers
