Stock rockers vs rollers
Old Aug 28, 2006 | 11:02 AM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Default Stock rockers vs rollers
I was wondering what the spec is on a stock rocker vs a 1.52 roller. Or is the difference only that a roller has a roller tip ?? Is there really a dramatic gain in roller rockers ?? I was told that the gain is allmost un-noticable in non-race allications.
Old Aug 28, 2006 | 11:57 AM
Gordonm's Avatar
Gordonm
The stock rockers range from about 1.46 to 1.48. They are not very accurate. The roller tips are a true 1.52. Going to a full rooler is not needed until you get spring pressure above 350 pounds of open pressure. Basically roller cam springs. There has been a huge amount of discussion on this before and you will get many opinions. I ran roller tips for years on a good size solid cam to 7000 rpm with no problem. I recently went to a full roller rocker but I also plan on a solid roller cam in the future.
Old Aug 28, 2006 | 02:37 PM
Little Mouse's Avatar
Little Mouse
if you are going to do it, buy 1.6 rockers and the pushrods you
will need. If you are expecting to gain anything, the extra lift is
what will do it.
To Stock rockers vs rollers
