If you have the correct pickle fork ( and not a ball joint fork it should come out ) But the best is to smack the side That usually always causes it to drop out. The impact on the side is by far the best. :smash:
paso,
Thanks for the reply. I actually went back down and tried again and the pickle fork worked this time. I guess soaking it with WD40 last night did the trick. All back together now and moving to the left side. Wish me luck!! :yesnod:
