flickering dash lights 1970coupe
Old Aug 29, 2006 | 01:30 PM
1970ls5ac's Avatar
1970ls5ac
4th Gear
Default flickering dash lights 1970coupe
my speedo, tach, and gage cluster lights are flickering when i turn my headlights or parking lights on. It is as if they have a strobe effect. grounds are new and clean. headlamp switch is brand new along with all the harnesses in the vehicle with the exception of the tail lamp harness. my exterior lamps DO NOT flicker and the courtesy lamps do not flicker. any ideas???
Old Aug 29, 2006 | 08:42 PM
69BigBB's Avatar
69BigBB
Default Dash wiring ground
Where did you find you dash ground?
Old Aug 29, 2006 | 09:58 PM
1970ls5ac's Avatar
1970ls5ac
4th Gear
Default grounds
its been a while since i have put it togetherb ut i believe they were alang the sides behind the kick panel and on the metal structire behind the dash
To flickering dash lights 1970coupe
