In some cases. But it depends. Two cams with the same duration and one with a wider LSA will retard the intake closing point which bleeds off low rpm cylinder pressure but has a lower overlap event. Tighter LSA also doesn't unto itself cause low vacuum. With a tight LSA, you can loose vacuum due to the overlap and the more duration you have, the greater your overlap event. This overlap pollutes the intake mixture and causes weak cylinder pressure, which means lower vacuum. This charge dillution, by the way, is also what gives the cam the rumpty-rumpty sound at idle. A cam with modest duration (say around 220 at .050)with a wide 114 degree LSA will have higher idle vacuum than the same duration with tight 110 LSA because you still have efficient combustion at idle. But one component that matters is compression ratio. It kind of skews the result.
My best take on this is that it's hard to use absolutes on the affects of a cam unless you specify all the parameters.
110 will give you more pull out of the corners. The 112 will give you a better charge down the straight. Depends on the engine, track, gears, trans, car, driver.... you get my point.
Well if you can't put down the torque out of the corner now, then having more of it won't be much help. Sounds like you need to kill some midrange torque, which the wider LSA will do.
Cruise-In IV Veteran
Cruise-In V Veteran
I am theorizing. I havent driven the car in a couple of years. I am building an engine, rebuilding the suspension, and putting in new brakes and seats this winter.
I think having working brakes and a smoother idle will trump a little bit of torque in the corners.
I will be running 255/50-17 tires, so the amount of torque will be limited by the tires.
I have a Crane Powermax dual pattern in my car. It's got 216 degrees intake and 228 degrees exhaust duration at .050 and 112 degree lobe centers. The idle is noticeable but the engine will idle down to a lumpy 750 rpm. I usually keep it at 800~850 rpm at idle and I get about 14~15 inches of vacuum and have no problem with the vacuum systems on the car.
