Rear Bearings
Old Aug 29, 2006 | 07:52 PM
Jims79's Avatar
Jims79
Default Rear Bearings
How can you tell if your rear wheel bearings are bad??
Old Aug 29, 2006 | 08:38 PM
mkflanagan's Avatar
mkflanagan
Jack up the car and wiggle your wheel if it moves around AT ALL you have a bad bearing
Old Aug 30, 2006 | 08:31 AM
Vette Gator's Avatar
Vette Gator
Mine made a humming sound that got louder at higher speeds, even though there was no wheel play. The tops of the outer bearing races turned out to be completely pitted and gold-colored, though the other areas were fine. Weird.
Old Aug 30, 2006 | 10:41 AM
Cookwithvette's Avatar
Cookwithvette
Mine squeaked.
Old Aug 30, 2006 | 10:49 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
3 & 9 o'clock will tell you if the bearing are bad. 12 & 6 will let you know if the side yokes are getting to worn.
To Rear Bearings
