how do the rear seat mounts....
Old Aug 29, 2006 | 09:32 PM
dholifield's Avatar
dholifield
Default how do the rear seat mounts....
bolt in? never noticed but the rear bolt/bolts are missing out of my seats. the end of the track has two holes, but there is a single hole in the floor directly behind the tracks. does this take two bolts, or am i missing a section of track that goes back to the single hole? BTW, it is a 72 model. thanks Don
Old Aug 29, 2006 | 09:48 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The rear seat track should have two holes in it and two bolts that secure it to the floor of the car. People that break off the bolts when removing the seats tend to just bolt the seats down where they can instead of removing the broken bolt or replacing the reinforcement.
Old Aug 29, 2006 | 10:19 PM
...Roger...'s Avatar
...Roger...
2 bolts at the front of the seat and 2 bolts at the rear of seat--in the rear of seat there are 2 holes in the seat slide on each side but I think there is only 1 hole actually drilled and tapped on each side in the body-4 total bolts holding 1 seat down
Old Aug 29, 2006 | 10:20 PM
68BLUEVETTE's Avatar
68BLUEVETTE
Old Aug 29, 2006 | 10:27 PM
dholifield's Avatar
dholifield
thanks for the info, but would anyone have any idea what the hole, about and inch and a half behind the track is for? thanks
Old Aug 29, 2006 | 11:03 PM
...Roger...
The track goes back almost all the way-are you sure the front is in the correct spot?
Old Aug 29, 2006 | 11:07 PM
dholifield's Avatar
dholifield
Not sure if they are or not. is there somewhere on the web i could view a picture of the tracks? thanks again
To how do the rear seat mounts....
