Plastic Vacuum Resevoir for C3
Old Aug 30, 2006 | 08:37 AM
80vetter's Avatar
80vetter
Cruising
Default Plastic Vacuum Resevoir for C3
Years ago I saw a plastic replacement for my Vacuum Resevoir for my headlamps. However I can no longer find where I saw that. Can someone help me to locate that or steer me in the direction of a cheap place to buy one.
Thanks.
Old Aug 30, 2006 | 09:29 AM
SIXFOOTER's Avatar
SIXFOOTER
Jegs PN 555-63010 $29
Old Aug 30, 2006 | 02:55 PM
80vetter's Avatar
80vetter
Cruising
Default One more quick question.
Thank you so much for doing that. Especially for the part number.
Do you think it matters though that the fittings are not the same as what I originally had?
Old Aug 30, 2006 | 03:00 PM
SIXFOOTER's Avatar
SIXFOOTER
No, all you have to do is connect it up. Vac source on one side and the two headlight relays on the other
To Plastic Vacuum Resevoir for C3
