Where to mount electric fuel pump?
Old Sep 10, 2001 | 01:53 PM
Marks69BB's Avatar
Marks69BB
Default Where to mount electric fuel pump?
I currently have a Holley pump which Bubba mounted on the frame near the starter(??). Where should it be mounted - near the tank in the back or up front somewhere?
Also, the gas line comes from the pump up the pass side of the engine near the dipstick to a T-shaped fuel pressure adjustment and then under the wiper door actuator and then up over the intake manifold through a fuel pressure gauge to the 850dp carb in a combination of rubber and copper lines. I've noticed that the stock way is chrome plated copper tubing routed up the front side of the block above the timing cover and back to the carb which I prefer. Would you leave it where it is or move it to the front? As always, thanks for the advice!! :cheers:
Old Sep 10, 2001 | 02:02 PM
Tom73's Avatar
Tom73
Default Re: Where to mount electric fuel pump? (Marks69BB)
My understanding is that electric pumps do better at pushing then at pulling. So it should be mounted close to the tank.
tom...
Old Sep 10, 2001 | 02:31 PM
The Wanderer's Avatar
The Wanderer
Default Re: Where to mount electric fuel pump? (Tom73)
You are correct Tom ... mount the electric fuel pump back by the tank.
Old Sep 10, 2001 | 02:39 PM
ED DINAPOLI's Avatar
ED DINAPOLI
Marks69BB,
An electric fuel pump should be mounted as close to the tank as possible. I mounted mine on the outside of the frame rail on the passenger side. I would put a fuel filter between the tank and the pump [ you cant believe what comes out of the tank].
If you mount the pump in the rear you can run your fuel line up the front of the block as the original line did.
Ed
Old Sep 10, 2001 | 02:40 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Where to mount electric fuel pump? (The Wanderer)
Mine is mounted on the Diff cross member on a steel plate. the the routing is the same, I don't like the fuel lines going all the way around the engine.
Old Sep 10, 2001 | 02:44 PM
69ttop502's Avatar
69ttop502
Mark that is an interesting question because on my 502 the pump is mounted where yours is. I always heard also that the electrics do a better job pushing than pulling but Jim Pace did the installation of my motor (before I owned the car) and they are a knowledgeable performance shop I guess and they mounted it there so I will be interested in the replies. Mine is the 50 gph GM performance parts pump.
Old Sep 10, 2001 | 05:25 PM
nastee383's Avatar
nastee383
Mine is on the rear bumper support just below the tank.
Old Sep 10, 2001 | 07:52 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
I mounted mine on the inside of the passenger frame rail right behind the diff cross member. One concern brought up in another thread was proximity to exhaust pipes. I have side pipes so that was not an issue.
Dave
Old Sep 10, 2001 | 08:05 PM
RatRacer's Avatar
RatRacer
Default Re: Where to mount electric fuel pump? (nastee383)
[QUOTE]Mine is on the rear bumper support just below the tank.
QUOTE]
So is mine. I also wired in an inertia switch from a '92 Mustang. It will cut the fuel pump off during a collision. Otherwise the fuel pump could continue to pump fuel out of a ruptured line. Just add a spark and you are fried chicken.
Old Sep 10, 2001 | 09:00 PM
GDaina's Avatar
GDaina
It really doesn't matter where you mount it, front by the motor, middle, or close to the tank. I've seen pumps mounted all over the place, even by the rad core support, and they all work. Mine, like most is mounted on the outside of the rear frame by bumper support
To Where to mount electric fuel pump?
