Clutch question
Old Aug 31, 2006 | 10:06 AM
noel48's Avatar
noel48
St. Jude Donor '14
Default Clutch question
On my C6 the clutch engages about an inch from the floor,however on my '78 it doesn't engage until maybe 4-5" from the floor.Is this normal?
Old Aug 31, 2006 | 10:09 AM
rihwoods's Avatar
rihwoods
No...should be around 1 1/2"......
Old Aug 31, 2006 | 10:42 AM
straub18045's Avatar
straub18045
noel what up im from easton,pa
-not sure if i would worry unless its slipping, but i have drove some
c3's that did pull alittle high
Old Aug 31, 2006 | 10:51 AM
rihwoods's Avatar
rihwoods
On a 78 with fresh clutch, adjustment (freeplay) is normally 1" - 1 1/2"...are you sure you are at 4 - 5" ??
Old Aug 31, 2006 | 11:13 AM
karioth's Avatar
karioth
yeah 4-5" is a LOT. Sounds like you need an adjustment
To Clutch question
