Performance Fuel Pump Recommendations Please
Old Sep 10, 2001 | 05:16 PM
nunus79's Avatar
nunus79
Default Performance Fuel Pump Recommendations Please
I need your advice for a reliable street/strip performance fuel pump setup for a SBC. What are the pro's & con's of mechanical vs. electric pumps? All replies appreciated.
Old Sep 10, 2001 | 07:44 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Performance Fuel Pump Recommendations Please (nunus79)
I just put on a Holley fuel pump. I don't remember the model number but its the chrome one that doesn't require a regulator. Right now its pumping about 8PSI. Cost $49 or so. Don't think I'll need much more than that.
Old Sep 10, 2001 | 08:45 PM
yosshimura's Avatar
yosshimura
Default Re: Performance Fuel Pump Recommendations Please (1970 Stingray)
Why would one need a "performance" fuel pump on an otherwise stock engine? :confused: . Could the stock carb handle that extra amount or fuel or would rejetting be in store? I just changed my fuel pump and wasn't sure, so just went with a stock on on a stock 350. :blueangel:
Old Sep 10, 2001 | 08:54 PM
7Bob3's Avatar
7Bob3
I run a Holly 327-2. It puts out around 9psi and 100 gph. Would suggest a regulator if you go this route.
Congrats on the 13.
[Modified by 7Bob3, 5:05 PM 9/10/2001]
Old Sep 11, 2001 | 03:30 AM
nunus79's Avatar
nunus79
Default Re: Performance Fuel Pump Recommendations Please (7Bob3)
Thanks for the suggestions guys. Thanks Bob ;)
Old Sep 11, 2001 | 04:15 PM
Matt Gruber's Avatar
Matt Gruber
nunus
i got my GNPP from Scoggin-dickey #6415325 21.95 $29 with shipping.
list is $56 at my local dealer :confused:
it's described in the GM Performance Parts catalog.
it is an excellent single valve pump, so it's flow is higher than stock, but less than the triple valve holley and carter pumps.
it can be rebuilt too!
Old Sep 12, 2001 | 08:36 AM
Ganey's Avatar
Ganey
The Holley chrome one is fine. Mech. increase flow w/ rpms. Elect. has higher pressure & needs a cutoff switch.
Old Sep 12, 2001 | 03:33 PM
nunus79's Avatar
nunus79
Default Re: Performance Fuel Pump Recommendations Please (Ganey)
Thanks for the recommendations guys.
Just noticed Cappy (Bionic) & Maurice planning on major gear changes. maybe I gotta go NOS just to keep up. Do you think the mechanical pumps can keep a wet spray setup happy?
Old Sep 12, 2001 | 04:10 PM
gkull's Avatar
gkull
I think that I would order the one drives61 suggested. I would not run any carb I owned over say 7 psi. and on a bypass system they work fine at 5. I have never run out my double pumper bowls at high rpm on the floor for in excess of 30 seconds. There is no need to over pressure them. The bowls are vented and proper float level and needle/seats maintain a correct level.
I would not use NO2 without a fuel log and a regulated system.
Old Sep 12, 2001 | 05:39 PM
robzr's Avatar
robzr
They Carter pump flows more and costs less than they Holley. I think it looks nicer too.
Rob
Old Sep 12, 2001 | 08:56 PM
nunus79's Avatar
nunus79
Default Re: Performance Fuel Pump Recommendations Please (robzr)
Just took a look at the Carter mechanical pumps in the catalogs. Good suggestion, very much appreciated.
I would like to thank you all for your replies. Means a lot to me when you get help from guys whose opinions I've come to highly respect. Thank you.
To Performance Fuel Pump Recommendations Please
