new engine problem
Old Aug 31, 2006 | 07:15 PM
STEVES59's Avatar
STEVES59
Default new engine problem
Whats your thoughts on new gm 350 290 horsepower crate engine making 125 pounds of compression and 11 inchs of vacume @ idle. valves are sealing cam timing verifys. no vacum leaks
Old Aug 31, 2006 | 07:59 PM
lucky76's Avatar
lucky76
Compression sounds a little low.
Old Sep 1, 2006 | 01:46 AM
jimmymac1949's Avatar
jimmymac1949
5th Gear
sounds like your valves may be adjusted too tight.
Old Sep 1, 2006 | 08:02 AM
STEVES59's Avatar
STEVES59
Valves are sealing
Old Sep 1, 2006 | 08:03 AM
STEVES59's Avatar
STEVES59
I felt it is too. thought it should be 150 to 160
Old Sep 1, 2006 | 08:34 AM
SIXFOOTER's Avatar
SIXFOOTER
Squirt a little oil in the cynender and try it again, the comp should come up if its rings not seating
Old Sep 1, 2006 | 09:39 AM
TopGunn's Avatar
TopGunn
Marvel Mystery Oil
Old Sep 1, 2006 | 09:48 AM
STEVES59's Avatar
STEVES59
Oil in cylinders had no effect, Think there is an assembley issue with the rings
Old Sep 1, 2006 | 09:49 AM
SIXFOOTER's Avatar
SIXFOOTER
uh oh, thats not good.
To new engine problem
