L48 vs. L82
Old Sep 10, 2001 | 08:27 PM
Kloppy80's Avatar
Kloppy80
Default L48 vs. L82
Other than 40 HP, what is the difference between an L48 and L82? Or how did they get 40 more HP out of the L82 :rolleyes:
Old Sep 11, 2001 | 12:09 AM
Double Aught's Avatar
Double Aught
Default Re: L48 vs. L82 (Kloppy80)
L82: forged crank & pistons. 2.02 intake valves. 9.1 CR. Makes power after 2500 up to 6000. Aluminum intake. Four bolt mains.
L48: cast crank/pistons. 1.94 intake valves low eights on compression. More torque at low rpm. Lower red line. Two bolt mains.
If you plan to keep the original engine and use it to build, get the L82 simply for the stronger internals. Other that that, not much diff.
Old Sep 11, 2001 | 12:42 AM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
What is the redline on the L-82?
Old Sep 11, 2001 | 12:50 AM
Double Aught
Default Re: L48 vs. L82 (joeveto)
6000
Old Sep 11, 2001 | 01:16 AM
Tom73's Avatar
Tom73
Here are the specs for '73:
tom...
Old Sep 11, 2001 | 08:03 AM
UKPaul's Avatar
UKPaul
Default Re: L48 vs. L82 (Tom73)
OK, so the L82 has the stronger bottom end but what sort of HP/Torque output would be the limit for an L48 before the bottom end would give cause for concern?
Paul
Old Sep 11, 2001 | 08:11 AM
Neo Fender's Avatar
Neo Fender
Default Re: L48 vs. L82 (UKPaul)
I've seen two bolt blocks used successfully for mild racing engines. Quality hardware is the key. Should be fine for just about any street engine. A machine shop can convert a two-bolt block to a four-bolt. The outer bolts are splayed from the conversion, making it even stronger than a OEM 4-bolt block.
Old Sep 11, 2001 | 11:48 AM
Ken74Conv's Avatar
Ken74Conv
Does anybody know if these specs are the same for 1974?
Thanks,
To L48 vs. L82
