Window Track Cleanup
Old Sep 2, 2006 | 08:46 AM
captainmorgan's Avatar
captainmorgan
Default Window Track Cleanup
My power windows go up and down slow on my '77. What is the easiest way to get at the window track to clean it up and re-grease? What kind of grease should I use? Should I also re-grease the power window motor? Any other tips on what should be done while I'm in there would be appreciated.
Old Sep 2, 2006 | 08:52 AM
theandies's Avatar
theandies
Idon't have PW but when I was adjusting my window for my Convertible top install I took everything out. Taking the track out was easier than I thought it was going to be. It was a lot nicer having the tracks out so I could clean them up really good. I don't know what kind of grease the factory used but I used a small amount of high temp wheel bearing grease and put a small film along each track and wheels. Made a big difference on how the window functions.
Old Sep 2, 2006 | 09:32 AM
SIXFOOTER's Avatar
SIXFOOTER
take them out, clean thuroghly and regrease with white lithium grease
Old Sep 2, 2006 | 10:23 AM
Edzred72's Avatar
Edzred72
You have to take everything out to clean properly, and the Lithium grease has the right consistancy (not too thick at low temps)
Here is something that might help.
Eddie
Old Sep 3, 2006 | 01:26 AM
Steve COSD's Avatar
Steve COSD
Eddie
If you take the whole lift assembly out make sure you put a bolt and nut through the large hole that is beneath the spiral spring. This will keep the tension of the spring in check if you remove the motor from the regulator. Also if the parts are old replace them with new at this time. All the parts are available from most Corvette Parts sellers.
Good Luck
Steve
Old Sep 3, 2006 | 03:30 AM
camaroneil's Avatar
camaroneil
my 77 windows go up and down slow,
turns out to be the spring that is snapped,
natt
Old Sep 3, 2006 | 09:41 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Great pic Eddie. Right click and save on that one. Could come in very handy for a long time, especially in post like this one.
To Window Track Cleanup
