Help removing pass lower A-Arm
Old Sep 2, 2006 | 08:59 PM
scottw's Avatar
scottw
Default Help removing pass lower A-Arm
I have the upper A-arm removed,which I thought was going to be the hard one. One the lower A-arm, passanger side, I have all three bolts off. The singe bolt and nut located on the rear side of the a-arm has the nut off but the bolt won't budge. I cannot get to it due to engine clearance. Is this suppose to slide off or is it suppose to unscrew? If it unscrews, how to you get to it?
Thanks for the help.
Scott
Old Sep 2, 2006 | 09:09 PM
shafrs3's Avatar
shafrs3
You do have the spring out, right? Sorry but I have to ask that question.
Old Sep 2, 2006 | 09:11 PM
scottw's Avatar
scottw
Spring, sway bar, everything is out. It just won't come off the rear bolt. The front two bolts came out easy. I can wiggle it back and forth about 1/4 inch but it won't slide down the last bolt.
Old Sep 2, 2006 | 09:18 PM
shafrs3's Avatar
shafrs3
Those three bolts are the only thing holding the arm to the frame, try a pry-bar to separate it from the frame. Normally they just fall off, maybe yours has had some damage and needs additional persuasion.
Old Sep 2, 2006 | 10:00 PM
chris75stingray's Avatar
chris75stingray
i just took mine off. i couldn't get the back bolt out either because the trans cooler lines were right on top of it. but it still fell right out when all three bolts were loosened
Old Sep 2, 2006 | 10:08 PM
scottw's Avatar
scottw
I guess I will have to give it a little pry bar help tomorrow morning. I've already got frustrated tonight and cracked open some beer and started watching football.
Go Vols!!
Old Sep 2, 2006 | 10:46 PM
SmokinBBC's Avatar
SmokinBBC
I put a socket wrench up there and turn the bolt..after you turn it, it will loosen up and the a-arm will come down.
Old Sep 3, 2006 | 11:22 AM
scottw's Avatar
scottw
After using a prybar this morning, I have yet to loosen the bolt.
I am pretty sure it is rusted on the inside of the a-arm sleeve. I can turn the a-arm about 1/4 of an inch and the bolt moves along with the a-arm. I am using WD-40 to try and get the rust to break up a little. Any suggestions??
Old Sep 3, 2006 | 11:33 AM
yukon988's Avatar
yukon988
I think you are on the right track. The bolt is a snug fit but not screwed in. If there is any way you can get to the head on top to turn it, that could help but I know its a tight fit up there. On mine, after removing the fan and fan shroud, I was able to get to it from above.
Old Sep 3, 2006 | 04:42 PM
Hammerhead Fred's Avatar
Hammerhead Fred
My first post ever on this forum was for this exact same problem.
http://forums.corvetteforum.com/show....php?t=1030086
Check it out.
Old Sep 3, 2006 | 05:58 PM
72LS1Vette's Avatar
72LS1Vette
Use PB Blaster instead of WD40.
Rick B.
Old Sep 4, 2006 | 07:59 AM
scottw's Avatar
scottw
Thanks hammerhead. Looks like a usual issue. I guess I'll keep soaking it and try some heat. I'm going to do everything possible before removing the radiator, fan, etc.
Old Sep 4, 2006 | 07:20 PM
scottw's Avatar
scottw
Finally got the a-arm off. I kept soaking it all weekend and a little help with an air hammer got it loose and slowly came out.
Now it's on to the driver side.
Thanks for all the advice and help.
To Help removing pass lower A-Arm
