Lower Ball Joint ??
Old Sep 3, 2006 | 03:21 PM
SIXFOOTER's Avatar
SIXFOOTER
Default Lower Ball Joint ??
Which side does the Big Headed bolt for the lower ball joint go on? Book doesn't say and I can't remember
TIA
Danny
Old Sep 3, 2006 | 03:31 PM
Bob Onit's Avatar
Bob Onit
Does this help at all Dan?
http://docrebuild.com/dr-r-web/SUSP63A.pdf
Old Sep 3, 2006 | 03:44 PM
norvalwilhelm's Avatar
norvalwilhelm
TIA
Danny
It's to limit wheel turning. If you put the big headed bolt to the front it will NOT contact the steering arm and limit turning radius. Put it to the back.
Old Sep 3, 2006 | 04:04 PM
SIXFOOTER's Avatar
SIXFOOTER
Ahhh, thats what I thought, thanks Norval
Old Sep 3, 2006 | 04:49 PM
norvalwilhelm
Now that I have given you the answer and you have properly thanked me I could be wrong
Check if there is a built in stop on the lower A arm. If it does have a fixed stop then the big bolt head goes to the front. Look carefully at the old one. If you turned the wheel full lock will the steering arm, that arm the out tie rod attaches to , does it hit something on the lower A arm? If it does the bolt goes on the opposite side or front. If there is nothing on the back of the arm to stop the turning radius then it goes on the back.
I really think I mislead you in my first post.
Old Sep 3, 2006 | 05:24 PM
Twin_Turbo's Avatar
Twin_Turbo
the steering stop is indeed on the back, the steering arms have the bulges on them that butt againts the bolt.
You can see the flat faced bulges that run against the bolt here:
Old Sep 3, 2006 | 06:09 PM
norvalwilhelm
Thanks Marck. My memory was just a little foggy but at the time if you just look at it it all makes sense.
Old Sep 3, 2006 | 10:17 PM
SIXFOOTER's Avatar
SIXFOOTER
LOL, yea I got it done Norval, had to do it twice, had 2 out of 4 parts not fitting together first time, second one went together a lot easier after the first one was right.
To Lower Ball Joint ??
