cam advanceing ?
Old Sep 3, 2006 | 11:24 PM
Billysvette's Avatar
Billysvette
Default cam advanceing ?
Can someone on here explain how to advance a cam a couple degrees?
Old Sep 4, 2006 | 12:12 AM
SIXFOOTER's Avatar
SIXFOOTER
I think it requires an adjustable cam gear. It has 2 or 3 index positions instead of the norman 1
Old Sep 4, 2006 | 12:15 AM
mr303's Avatar
mr303
If you have the factory timing gear and chain then you can't do it. You will have to upgrade to a aftermarket chain and gear set. Advance or retard setting can be made to the crank with some sets or to the cam with other sets usually in increments of 2 degrees. Have a look at summit web site to get some priceing and brand options. Cam degreeing can be done with the engine in the car but can be akward, but still easier than pulling the motor to do it.
Old Sep 4, 2006 | 02:14 AM
jackson's Avatar
jackson
Yes, even with factory timing set, you can advance or retard. First buy a "cam bushing kit" ... remove top (cam) gear ... drill cam pin hole out ... press in eccentric bushing from kit ... reinstall cam gear ... align timing marks ... button it up ... done. Several companies such as Comp & Mr Gasket offer cam bushing kits. This job can also be done using OE t set along with an "offset crank key" ... that's an offset woodruff key ... installs with lower crank gear. The first method using cam bushing is easier. Or, for under $25 you can buy a whole new timing set that has 3 keyways (advance 4, stock, retard 4) ... check a Cloyes P/N C3023X. Best solution is a new timing set.
Old Sep 4, 2006 | 08:42 AM
marshrat99's Avatar
marshrat99
Forum Brothers and Sisters, could this also be accomplished by adjusting the dist to cam gear tooth alignment?
Also wondering why rotating the dist wouldn't give enough adjustment?
Old Sep 4, 2006 | 08:48 AM
1970-Bronze's Avatar
1970-Bronze
No, moving the distributor only changes the spark timing.
Changing the relationship of the cam to the crank changes valve timing.
Old Sep 4, 2006 | 08:49 AM
Fevre's Avatar
Fevre
No that just moves the timing of the spark, advancing the cam changes the relationship of the valve events to the location of the piston in the cyl
Old Sep 4, 2006 | 09:11 AM
Billysvette
Thanks so much
Old Sep 4, 2006 | 10:35 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Your Timing sprogs probably have symbols to line up. My timing chains also come with marks to advance and retard the cam by rotating the cam relative to the crankshaft and then putting on the timing chain.
To cam advanceing ?
