I believe the Jeep steering gear from 1999 to 2004 is a Delphi 600. I don't know if that's the one you are asking about. Concept One Pulleys is working on another gear but it is not ready yet.
There's a place called Corvette Steering or something that uses the Jeep box with an adapter to bolt into a C3. Or you can just hack away at your frame and fit it in like Norval did.
G'day,
Call Kevin Redd at Concept One Pulleys on 1-877-785-5397 or www.conceptonepulleys.com. They use a new Delphi 600 power box, but add a longer lower housing and longer Pitman shaft to clear the Corvette chassis. They also supply the correct Pitman shaft but you will need to use a manual (non-power) relay rod or centre link and I advise that you also get their steering coupler, as the old one won't fit.
I believe that the cost is US$795 for the box and US$75 for their coupler, while relay rods are about US$60 second hand. The company is located in Cumming, Georgia.
