Need help finding VIN on engine
Old Sep 4, 2006 | 04:09 PM
noel48's Avatar
noel48
St. Jude Donor '14
Default Need help finding VIN on engine
'78 L48.Anyone have a pic where I can find it?
Old Sep 4, 2006 | 04:26 PM
Artsvette73's Avatar
Artsvette73
Right in front of the passenger side head. There is a pad that sticks out on the top of the block. There will be some letter code and then your seguence number of your vin.
Old Sep 4, 2006 | 08:08 PM
noel48's Avatar
noel48
St. Jude Donor '14
Do I have to remove anything to see it?
Old Sep 4, 2006 | 08:19 PM
72LS1Vette's Avatar
72LS1Vette
Just 20+ years of crud and old oil.
Rick B.
Old Sep 4, 2006 | 08:23 PM
gmviso's Avatar
gmviso
The numbers are stamped in not forged, so they can be kind of hard to see. I had to look twice. You need a good light. You should look straight down in front of the head and there will be a flat section of the block where the numbers are. Good luck.
Old Sep 4, 2006 | 10:13 PM
MsVetteMan's Avatar
MsVetteMan
Get a piece of steel wool or sandpaper and sand the paint and crud off. It's most likey there.
Old Sep 4, 2006 | 10:50 PM
Mike Ward's Avatar
Mike Ward
Please don't take anything abrasive to a stamp pad. You'll remove the broach marks which are crucial to determining if a pad is original or not.
Old Sep 5, 2006 | 12:43 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Can't quite read it in this pic but there it is.
Old Sep 5, 2006 | 08:47 AM
merlin5353's Avatar
merlin5353
St. Jude Donor '07-'08-'09-'10
Whah Where ???
Old Sep 5, 2006 | 10:18 AM
MsVetteMan's Avatar
MsVetteMan
I can assure you that by hand sanding the paint off the lip edge of the block, you won't hurt a thing, and just imagine, you will actually be able to see, and read the numbers!!
ZR-1 Mark's Avatar
ZR-1 Mark
Even through the paint, that looks correct.
You can make out the "S" in the front of the vin,
and the "C**" denoting the horsepower combo.
Now get that paint off there so we can see
Old Sep 5, 2006 | 10:23 AM
MsVetteMan's Avatar
MsVetteMan
And let me give you another reason to check those numbers. When I bought my '74 vert project a few months ago, the owner said it was a nom. He was certain. (He was not the original owner). When I inspected it, and checked for numbers, it did appear as though the block had been decked because I couldn't see or feel the numbers on the front pass. side. I assumed, as he assumed, that it was a nom. Well, car was in the garage a couple of weeks, and I decided to look again for the vin number on the front block. Got a piece of fine grade steel wool and started rubbing the ledge. Well, I'll be, I found some numbers, and they match the vin. Numbers matching original motor in a car with 75,000 miles.
Old Sep 5, 2006 | 12:33 PM
KapsSA's Avatar
KapsSA
Originally Posted by merlin5353
Whah Where ???
On the flat spot where the water pump bolts . I know what my numbers are, posted the pic for noel48 to see location.
Old Sep 5, 2006 | 01:18 PM
emccomas's Avatar
emccomas
I also advise caution about using anything abrasive on the engine pad. If you use an abrasive material, and it leaves any marks on the engine pad, you will bring the authenticity of that engine pad into question in the future.
Use something like lacquer thinner to remove the paint from the engine pad.
Old Sep 5, 2006 | 05:57 PM
noel48's Avatar
noel48
St. Jude Donor '14
Thanks guys Will look tomorrow when I have more light.
Old Sep 5, 2006 | 06:24 PM
wfo76's Avatar
wfo76
yeah, lacquer thinner and a toothbrush will clean it up nice without damage
To Need help finding VIN on engine
