Where is the ground cable for the instument cluster located? they all quit working @ 1 time and I have checked all of the fuses. But I can not seem to locate where the ground is located to check that
Sorry If I led you down the wrong path...
What quit working? the gauges or the lights?
I know that there is a black ground wire somewhere up under the dash on the drivers side. I don't know if this affects the instrument cluster though because the cluster has its own electrical connector (set of copper fingers)
I'll what else I can find for you tonite.
Rob
