Should I save these?
Old Sep 11, 2001 | 10:53 AM
69ttop502's Avatar
69ttop502
Default Should I save these?
I just replaced the original spring and rear end cover on my 69. The spring had a little sag and the rear end cover had a chip which I thought was where one of the spring mount bolts is but it turns out it wasn't so structurally it is probably ok but the new vette brakes one looks so much better. My question is are these two things worth saving for the next owner or do they hold any value to the car? Thanks.
Old Sep 11, 2001 | 08:59 PM
JCL's Avatar
JCL
Default Re: Should I save these? (69ttop502)
69TTOP502. REPLACED MY SPRING LAST FALL AND LAID THE OLD SPRING IN A CORNER. THEN IN ABOUT A WEEK I SAID A NEW LEAF I'M GOING TO TURN. TWAS NO GOOD WHY KEEP IT. TO THE TRASH IT WENT. ONE LESS THING TO KEEP MOVING AROUND THE SHOP!!! LATER, JCL :cool: :chevy
Old Sep 11, 2001 | 11:16 PM
Bill W's Avatar
Bill W
I would hold onto it. Thre are no accurate reproduction springs made that I am aware of. So, its probably worth a bit to someone doing a factory correct restoration. Also, depends on how bad the sag is. If you can still get the rear wheels aligned then its OK. The NCRS guys will go to great lengths to restore one of these.
To Should I save these?
