Seat Belt Help
Old Sep 5, 2006 | 10:32 PM
BFowlkes's Avatar
BFowlkes
Default Seat Belt Help
Does anyone have any idea how to bolt in the rear shoulder belt on a 1969 coupe that has the retaining bolt broken out of the reinforcing plate? I can get the bolt through but it is behind the frame rail on the passenger side and with the lines (fuel?) running on top of the rail and limited space I can't get to the gap between the inner fender and the frame rail to put in a nut. Any ideas?
Old Sep 5, 2006 | 11:48 PM
Artsvette73's Avatar
Artsvette73
Did you try from the inside of the frame? That support is only held on with rivets. If you drill them out you maybe able to weld the nut back on. If the bracket is any good. I had to replace mine. They looked fine on the outside but the inside you dont see was a mess
